Home > Maintenance & Mods (L322) > screen washer
Dave ray
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
screen washer
After a little help passenger side wont give any screen wash and rear wont give any wash ??
Post #224988 24th Nov 2013 6:54pm
Have you checked for blockages yet? As the drivers side is working, I would take the pipe off to the passenger side before the nozzle and check if there is flow. Just work back from there. Have you added any detergent recently? It could have gelled.
As for the rear, I take it there is not even a trickle? Previously..
Post #224994 24th Nov 2013 7:58pm
Remove the front washer, split it into two parts remove the orange plunger and spring comprising the integral non-return valve and throw away, reassemble and refit. Should work perfectly.
Why LR fit integral nrv's to the washers is beyond me, they work better without them.
Alternative is to buy new washer jet.
Post #224996 24th Nov 2013 8:05pm
Dave ray
Nothing from the back
Post #224999 24th Nov 2013 8:28pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
rear is caused by NRV sticking or full of gunk. remove and clean normally fixes Thumbs Up
Post #225001 24th Nov 2013 8:35pm
