Home > General > Is this a common part to steal?
See where you mean now ..... strange to steal that part Shocked ====================================
Post #224936 24th Nov 2013 2:25pm
Mark.abersoch
United Kingdom 2010 Range Rover Vogue SE TDV8 Bonatti Grey
They aren't the easiest thing to get off with out damaging anyway.
Weird for the to be taken! 2009 TDV8 Vogue SE - Bonatti Grey
Post #224939 24th Nov 2013 2:31pm
paneldamage
Aha get you Noddy, these do corrode though, bubbling under the rubber etc. I wonder if they have come loose, maybe had stuck to the glass a little in the frost and the action of the window going up and down has pulled it off..... Clutching at straws tho really, more likely to have benn pinched. strange tho.
Post #224945 24th Nov 2013 2:57pm
Andy
The car is fine. No lever marks or anything. I just hope the trims bent when the thieving gets took them
Post #224975 24th Nov 2013 5:16pm
Andy
Well no wonder someone stole them- they're £32 each plus vat!
For a piece of rubber - unbelievable
Post #225065 25th Nov 2013 9:33am
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Thats the very reason they will be nicked !! My sister lost the front screen from her ford fiesta many years ago when the screen was added to the MOT failures list ( marks in drivers area of vision, cracks ). Any make of car that had a non bonded screen was considered fair game.
Post #225303 26th Nov 2013 10:25am
johnboyairey
those strips definitely bubble and rot, i was trying to get some secondhand from dismantelrs, and had to wait a while as all in the yard were bad. i paid £15 each. i thought they were a lot more than £32 new though.
its sad that a felllow FFRR owner needs them that bad. he could just not drive it for a week, to pay for a couple of new ones!
worst thing i had nicked from a car, was the propshaft! i couldnt work it out at first. and garage didnt believe me, at first!
the worst thing that could be 'easily' nicked from the FFRR, could be the catalists. plenty of scum with those pipe slicing molegrips in their boot, flicked over each pipe, hooked on and back and forth, sliently cuts each pipe. and away, to the scrappers, £50 each mate. and about £1000 to replace. ive heard of van drivers having weld on parts fitted to pipes to make them less vulnerable. higher stakes on seconhand market for those trhankfully.
if leaving car in dodgy area, at least lower it! and check the seats are clear!
Post #225329 26th Nov 2013 12:21pm
