Home > General > What a day!!
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
What a day!!
So today the plan was to find and fix my cooling system leak, fit the new S5 battery then kick back and relax till it was time to go to work in the evening!! Shocked
To start off with the blue point coolant system pressure tester i bought fits near every make and model of car on the planet except Land Rover's!! Not to worry plan b was to just strip the water pump and thermostat out and replace the gaskets and liberally coat in gasket sealant!
I have never encountered so many seized and or rounded bolts in my life!! By this time i was starting to think we were jinxed but then again how much worse could it get! Sad
We get everything rebuilt and decide now's the time to swap out the battery. Using the disconnection procedure in the wiki the old Yuasa battery was out in no time. Trying to get the S5 in on the other hand was a pain in the arse! After 30 mins of crushed fingers and swearing she finally gave it up and slid in like a champ!! Hooked it up and away we go! Reversed the Rangie out of the Garage onto the drive way to start the flushing out of the Green coolant to refill with red. Once the water was running clear we started refilling with the good stuff and thats when it happened! Turning but no starting!! Now after the day we've had thus far you can imagine that there were perhaps one or two less than savoury words uttered! So, after i'd stopped crying we put in an SOS to our local Indy specialists seeking enlightenment. After explaining that we thought it was being starved of fuel we were told to grab a hammer and get down under the back passenger side wheel, drop the wee inspection hatch and with the ignition on batter the fuel pump. I initially thought he was on the wind up but being on the brink of petrol and matches we fired in and gave it hell! Sure enough she burst into life! I felt Dr Frankenstein, IT'S ALIVE!!!
She's been topped up, bled and is now hopefully leak free. Time will tell!
As i said, What a day!! Censored
Post #224447 22nd Nov 2013 2:35am
Fuel pump next on the list for changing then
Ah the joys of FFRR ownership Laughing Laughing Laughing
Post #224460 22nd Nov 2013 7:54am
paul271
It certainly is mate.
Can anyone confirm that the part no of the pump i need is: 4A194225 ?
I had looked it up on Microcat but for some reason i just can't use it!!! Confused
Post #224509 22nd Nov 2013 11:58am
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Hi
I bought one and fitted it last tuesday.
Part no WFX000181
Hope that helps. Easy to fit.
Cheers Piers
Post #224516 22nd Nov 2013 12:07pm
duckworthparts
Site Sponsor
superseeds to LR023043 £145inc vat You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #224517 22nd Nov 2013 12:13pm
paul271
Thank you chaps. As always much appreciated.
Dan is that for an actual Land Rover part?
Post #224518 22nd Nov 2013 12:15pm
duckworthparts
Site Sponsor
Paul
yes gen Land Rover part
OEM version £120inc, not sure who makes it though. You can paypal direct using - www.paypal.me/duckworthparts
Post #224524 22nd Nov 2013 12:23pm
