Home > Technical (L322) > TDv8 drive stutter
Page 2 of 3 <123>
Mikey
Injector cleaner is not going to help. You need to have it plugged in to determine which injector is at fault, and replace it
Post #207834 4th Sep 2013 5:54am
^ Injector cleaner, and a QUALITY one, works every time with this fault In my experience Thumbs Up
Post #207839 4th Sep 2013 6:24am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Dont know how easy access to the injectors is on the TDV8 but on a previous vehicle with easy access it was possible to feel the injectors pulsing and easy to identify the faulty one because it wasnt pulsing....
Failing that, I'd get the error codes read... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #207861 4th Sep 2013 7:47am
You wont get to them to feel them without stripping out loads (around 4hrs work) and then the car wont run anyhow!
Get a good quality inj cleaner, take the filter off and fill it with cleaner then put the rest in the tank...
Post #207866 4th Sep 2013 7:55am
BG244 Diesel Fuel System Cleaner
I use this and really does work... Thumbs Up
Post #207890 4th Sep 2013 8:37am
GGX
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
BG244 on order, thanks for all the help, fingers crossed.
Will get back from my work away job Friday, put it in Saturday drive to le tunnel on Sunday.
Post #208047 4th Sep 2013 7:08pm
GGX
Put the bg244 in and after 200 miles the eml came on for another 200 miles then went off.
Has stuttered once since.
Post #210394 15th Sep 2013 11:47am
Post #210395 15th Sep 2013 11:48am
GGX
So need to get it plugged in to see what the EML came on for?
Post #210398 15th Sep 2013 11:49am
But the stuttering is decreasing right? Neutral
Post #210401 15th Sep 2013 11:51am
adigorn
[/quote]So need to get it plugged in to see what the EML came on for?
Quote:
my money on egrs (unless you have changed them already)
Post #210406 15th Sep 2013 12:03pm
adigorn
Post #210407 15th Sep 2013 12:05pm
GGX
Yes better, so maybe give it another dose?
Still the original egr's, tdv8 has 2??
Post #210409 15th Sep 2013 12:08pm
adigorn
if never attended chances are minor that they r ok
(just changed one on 2009 MY yesterday 2h job)
Yes there is 2 and quite tricky to do
better change both at once
Post #210410 15th Sep 2013 12:12pm
Yes, it has 2 x EGRs.
I've been quoted £600 to replace both, which seems pretty decent as they cost around £200 each. Got - 2017 SDV8 Autobiography in Loire Blue
Post #210411 15th Sep 2013 12:13pm
Page 2 of 3 <123>
