Home > Technical (L322) > TDv8 drive stutter
Page 1 of 3 123>
GGX
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
TDv8 drive stutter
I'm getting an intermittent drive stutter when stopped and driving off, like the brakes are being jabbed?
What is that?
Post #206643 29th Aug 2013 10:12pm
Mikey
An engine misfre. Get the injector compensations checked on a diagnostic machine Thumbs Up
Post #206671 30th Aug 2013 5:39am
GGX
No dash warnings?
Post #206672 30th Aug 2013 5:57am
Definitely sounds like a sticky Injector buy some QUALITY fuel system cleaner and put that in then run for 20-50 miles it should clean it up and it should then be running smoothly. Thumbs Up
PS: Common on higher mileage TDV8.
Post #206694 30th Aug 2013 7:48am
GGX
It's got 83k, which cleaner is best not to damage anything- only happens when it's cold.
Post #207518 2nd Sep 2013 5:35pm
I always used redex injector cleaner. I would buy it from asda as it was always on sale, and double dose it every few months. There are quite a few cleaners for sale, I don't suppose any are much better or worse than the others.. Previously..
Post #207522 2nd Sep 2013 5:58pm
ebajema
sticky brake caliper ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #207534 2nd Sep 2013 6:59pm
GGX
Just changed the rear callipers, also got a shaking steering under heavy braking.
Post #207577 2nd Sep 2013 8:51pm
Injector, EGR or torque converter issue just starting!
Post #207629 2nd Sep 2013 11:51pm
Mikey
Completely seperate issue, warped front discs
Post #207632 3rd Sep 2013 5:56am
Sounds brake related to me, i would strip and clean all the calipers and then see what its like. I had a drive which felt like it was snatching a bit, turned out to be a sticking rear caliper, but if you have a judder under heavy breaking then i would get the runout checked on the front discs, however warping one of those big vented jobbies would be quite tricky.
The brembos are fairly robust but not beyond the possibility that one is sticking. Do the usual trick of having a 10-15 min drive round, then park up and see if any of the discs are still red hot. If so that caliper is sticking. There is nothing that can't be fixed with a hammer😜😜
Post #207785 3rd Sep 2013 8:31pm
GGX
Lumpy stuttering was worse tonight, seams to happen after a short drive and its left for a while then started agin. over 2000rpm it's ok, and once warm it's ok.
Ordered bg244 but think its going to need more than that, trouble is I'm going to France next week and worried now about the driving, Need a decent garage in notts.
Post #207796 3rd Sep 2013 9:14pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
If it stutters more frequently/worse after being run then left for a while (i.e. started whilst still warm) my money is on an injector problem
Not had any issues with my RR but I replaced two injectors on a previous car. Both times the problem was significantly worse when started from warm. Ultimate solution was to replace the faulty injectors.
That said, a couple of bottles of Redx cured a similar stutter on my wifes BMW 320D
I believe it was caused by the car not really doing any long trips before we bought it (36k in 5 years)
Try the Redx solution first - its cheap and wont damage anything.
The instructions say to put x amount in a full tank - I once spoke with a chemistry techy at the company who make it and he recommended a full bottle in 1/4 a tank or less if you really want it to work properly - this is what I do.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #207798 3rd Sep 2013 9:26pm
ok, with that info it does sound like an injector problem. DOes it feel like a misfire/like one cylinder is not running correctly?
You need to get it plugged in to identify the fault, and which injector is throwing up a code, cheaper than trial and error. Sorry but i have not had to use any of the indys round here yet, by all accounts Alan Smith Garages in derby is pretty good, however they were booked solid for a fortnight when i called to get a quote for some trailer electrics on my disco.
I also would run some injector cleaner through it followed by a tank of proper diesel, like shell optimax to see if that helps the problem but a code read should point to the answer. There is nothing that can't be fixed with a hammer😜😜
Post #207803 3rd Sep 2013 10:04pm
Rolling Eyes Whistle Yawn Embarassed
Post #207824 3rd Sep 2013 11:58pm
Page 1 of 3 123>
