Home > General > Hi all new member
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hi all new member
Hi all guys and girls I am just a new member on the site and just wanted to say I have posted a few questions up and hope to get some good help.
I will also help out where I can on posts.
I will be doing most if not all of the work on my car as I have a small garage and body shop
Not long had the car its a 54 reg RR L322 Td6 vogue one owner full history in silver
Just serviced it all filters and oil so I know its on new oil and filters
The torque convertors have been done and its on the new front diff
Just disabled the auto door locking at 5mph as it was a pest for me.
Just reset the SIA
Just put stainless side bars on looks great
Had the come on and reads no faults at all on the system so that's a great start.
Just a few bits I need to sort the air condenser has a pin hole in it to get fixed and re gassed up
A lower bush has a bit play so needs sorting
A minor oil cooler leak hope its the gasket as that's only about £3 hand don't look to bad to change out
SO ALL IN ALL HAPPY WITH WHAT I GAVE FOR THE CAR AND HOPE TO SORT IT AS I GO
Post #205590 25th Aug 2013 9:17am
Do you know/did you change the cam breather when changing the oil? Quite important Thumbs Up
Welcome Thumbs Up
Post #205594 25th Aug 2013 9:42am
steve9bug
Yes did the cam breather but thanks for the heads up, might fit the for life one next time but will see how it goes.
Like I said the torque and oil have been done but I will do the diff oils at a later date just for my own piece of mind
Post #205597 25th Aug 2013 9:48am
Thumbs Up no worries Thumbs Up
Post #205600 25th Aug 2013 10:00am
Phil H
Wales 2004 Range Rover HSE Td6 Adriatic Blue
Just had my TD 6 serviced, don't know if they changed the breather. Is it easy to see?
Post #205869 27th Aug 2013 7:43am
No phil it's not unfortunately! Important to have changed though! Confused
Post #205877 27th Aug 2013 8:22am
steve9bug
If you are mechanically minded then yes its easy job if not then no.
Best ask them if they changed it in the service if not do it.
The filter is not expensive or you can get a for life unit if you want to .
If not changed the filter clogs up and you start to get puffs of black smoke when you put yopur foot down and if left can lead to turbo failure so get it changed sooner than later.
Post #205891 27th Aug 2013 9:28am
Phil H
Thanks for the info. Will contact garage today.
Post #206037 28th Aug 2013 7:02am
Welcome Steve9bug, sounds like you will be able to give some great advice to the ever growing numbers of TD6 owners joining the forum.
Pics soon of your steed please Thumbs Up Discovery 4 HSE
Post #206045 28th Aug 2013 7:34am
