Home > Technical (L322) > odd gearbox issue when hot |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
blocked / ineffective ATF cooler perhaps? |
5th Aug 2013 1:57pm |
rmackinnon Member Since: 14 Mar 2012 Location: Mansfield, UK Posts: 85 |
worth looking at for sure. but if the cooler is blocked, why do i not get a transmission overheat warning.
5th Aug 2013 2:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35312 |
possibly the gearbox oil being low.. ... - .- -.
5th Aug 2013 2:58pm |
thanks - good note. I can get that checked shortly. In theory not, as it was topped up not long ago after a change. When the oil was low, i was getting gearbox "slips" when pulling out of junctions, often when cold. No issues like that now.
5th Aug 2013 3:09pm |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 |
I've had the gearbox go into cooling mode (holding gears high revs etc) but I also had a leaking radiator and made the assumption that the bottom rows of the rad were blocked and not cooling the gearbox sufficiently. Radiator has been changed and no problems so far.
5th Aug 2013 3:28pm |
That's the most interesting one yet!
5th Aug 2013 9:04pm |
no worries - just found this - is this what you mean?
5th Aug 2013 9:07pm |
Yep that's the one. The lower 8 rows of the radiator help cool the gearbox. Mine were clogged up as well as the rad having a leak. From what I have read it is a common issue on range rovers of the age of mine (2004). "On first name terms with my local Dealer......now."
5th Aug 2013 9:15pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 966 |
When you say “the gearbox goes into safe mode (without any alarms on dash)“ I assume you mean it locks in gear and doesn’t upshift or downshift, even when pulling away from rest? Can you tell which gear it’s locking in - 4th or 5th. This is significant.
5th Aug 2013 9:17pm |
Hi MRP - i will change the Rad and see if that helps - needs changing anyway due to the leak (have to put in about a litre a week at the moment which is diluting the coolant quickly.
5th Aug 2013 9:24pm |
If your transmission will upshift & downshift then it isn't in failsafe mode.
5th Aug 2013 9:47pm |
cheers! FFRR 2003 Vogue V8 |
5th Aug 2013 9:49pm |
Ok so I had / have the very same problem. Like you I also had a leaking rad which I have now had replaced at a main dealer but used a part supplied by duckworth. The rad is now Perfect however today I was in lots of slow traffic and the old gearbox issue happened again. Holding lower gears for higher revs until the gearbox had cooled sufficiently at which point it goes back to normal operation.
15th Aug 2013 7:05pm |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
Hy all,
15th Aug 2013 10:22pm |
