Home > Technical (L322) > Tdv8 (07) vibration at low rpm(D engaged) and ca 2200 rpm
andrzjb
2007 Range Rover Vogue TDV8 Java Black
Hi
Vogue tdv8 2007 with 100k miles on the clock,
I have all the time following symptoms
1) hot or cold at low rpm(1100 rpm) at each gear vibration
2)hot or cold at ~2000-2200 rpm at each gear justnbeforengear change position (automatic mode)high freq vibration feel in fool area and throtle pedal, vanished above mentionede rpm, more noticable during hard acceleration
Tc changed to new
Brakes and pads and calippers changed
Oils changed (all) gearbox two times
During "free wheels" testing where car is lifted only some sloght noise from rear diff( no vibration at all)
So is only noticable when car is under natural cirucumstances
No get worse during turning or reversing
No grunding juddering ,
What to check next?
Post #198220 9th Jul 2013 7:16pm
andrzjb
Big Cry nobody ? no ideas?
Today I lifted car one more to check automatic gearbox oil level all seems to be fine..
I also strat D with free wheels .. no vibration at all in mentioned rpm so its RPM & load related
assuming that its not (rather) propshaft, axles, cvjoints, or all bearings which are usualy speed related
no faults in ECU
please share your knowledge...
Post #198286 10th Jul 2013 7:32am
what size wheels do have fitted?
Also in a A&B above you do not mention if you are stationary or moving?
Have you checked engine mounts?
Post #198288 10th Jul 2013 7:46am
andrzjb
19 oem with new Vredestein Ultrac Sessanta balanced with stadard(no extraordinary LR) procedure?
Maybe its important .. before I changed TC I updated gearbox software to newest one... what coused that vibration at low rpm appeared... so now I get nicely changing gear (no slipping etc) with vibration at 1100 (each gear but mostly at first 2 gears) and 2200 (its usual postion when gears are switching to higher one)
at low speed vibration exists also when I take off foot from acc pedal (i.e. slowing down with enigne rpm)
and its make me crazy Censored
by the way.. is it any special method to check engine air mountings? Some weeks ago LR authorised dealer checked it only with diagnostic software and informed me that pressure is ok and visualy too?
according to my knowladge that guys in LR official services is a "changing specialists" not "House M.D" diagnositc masters.... Neutral
Post #198294 10th Jul 2013 8:08am
Can you reset the gearbox to the original software setting?
Post #198295 10th Jul 2013 8:10am
Is there any noise or just vibration? Could it be something loose? Mount, exhaust, etc.
I take it the gearbox works as it should? Previously..
Post #198296 10th Jul 2013 8:11am
andrzjb
probably ... I asked guys from another LR service they informed me that back to manufacturing soft is possible (of course with some extra charges Censored ) what is funny when you want to upgrade soft in Mercedes Benz AMG E63 (cost similar to new rangy) it cost you smth about 50 pounds(in Poland) LR price the same service for 100 pounds... crazy!!!!
but vibration at 2200 rpm "was& is" no matter new or old gearbox soft....
answering another question... at low rpm no additional sound or noises .. in 2200 rpm engine is louder however no noises like some parts touching another only engine.....
Post #198297 10th Jul 2013 8:19am
andrzjb
In stationary all is perfect no noises no vibration no matter how rpm is
Enigne mountings had been checked by LR ... but if you have some special "in house" method to check it i will do it for sure (I dont trust LR official service guys in Poland too much)
Post #198301 10th Jul 2013 8:28am
OK we can thankfully rule out any Engine problem then Thumbs Up
That leaves:
A) Torque Converter
B) Gearbox
C) Drive-line including Prop-shaft/Diffs/Transfer-box etc
A&B being the most likely. You may wish to try a full Gearbox Flush.
Post #198302 10th Jul 2013 8:30am
andrzjb
ad A) changed to new one one months ago(original ZF i.e not remanufactured etc) cost me about 600 punds with work of mechnics , of course full oil change (9,3 liter) and new filter with cover
ad B) hmm thats sound scary however no faults on ECU connected with GB and no vibration with free wheels lifted car driving even using a stethoscope touched to gearbox
ad C) yes.. however as I said... during "free wheels" driving with lifted car no vibration sounds noises etc.. only during normal ride condition, also manual checks with refer to clearances had not reveal any potantial causes of vibration.
According to ad B changing oils does not make any sense
Post #198310 10th Jul 2013 9:05am
Wheel Bearings ?
Post #198316 10th Jul 2013 9:23am
ebajema
I'm starting to lean towards injectors/fuel related issues. Even though no faults are logged related to the injectors, maybe one or two are not doing exactly what they need to.
When was the fuel filter changed last ?
Can you get good quality fuel system cleaner and run it throught ?
Can you get "good clean" diesel ?
Has you EGR been cleaned ever ? MY 2010 5.0 SC Galway green and sand interior!!
Post #198317 10th Jul 2013 9:33am
andrzjb
Arrow 5k km ago
Arrow not sure... need to figure out at gas station and services
Arrow yes always high quality (BP or Shell)
Arrow last time when i change termhostat cover EGRs had been checked.. quite clean
one question , how to check injectors .? out of the car on speclist table or via diagnositc soft? if soft how to do it to be sure ?
Post #198373 10th Jul 2013 6:07pm
Sounds like an injector fault to me, normally will show up on diagnostic tool, however you can get a garage to do a leak off test to confirm.
Even though not present at idle it may show up higher
In the rev range. There is nothing that can't be fixed with a hammer😜😜
Post #198377 10th Jul 2013 6:32pm
andrzjb
Hmm hopefully u r right.....however i dont See any smoke from exhaust and error codes on engine ecu
Post #198386 10th Jul 2013 7:23pm
