Home > Maintenance & Mods (L322) > Smouldering, Slamming, Rumbling, Steering |
Sounds like another classic SC problem, the brake calipers being stuck. Normally the rear calipers suffer this problem and most of us have had them changed. Sometimes it is accompanied by strange vibrations and "holding back". I initially feared a gearbox issue but then noticed the smell and hot rear disc.
25th May 2013 6:35am |
Thanks/ v much.. Will let you know later |
25th May 2013 6:41am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
I've had smoke pouring from my calipers before, plus a very bad shimmy through the steering wheel. At least your mpg will go up a wee bit once fixed |
25th May 2013 7:09am |
Would you please be able to elaborate as to how the steering shimmy manifested itself (main dealer -1week ago - replaced Servotronic valve and was asked to/ said they did fully inspect/ callipers, discs & pads and only query they found was to clean front brakes. I have queried that steering did still feel something small amiss too)?
25th May 2013 7:33am |
Violent shaking through the steering wheel, made the car undriveable . Never had a car react like that due to sticky caliper, Although never had such a heavy car either. Just go for a wee run as described above & touch your wheels when you pull over, it will be very obvious if any are stuck, as the wheel will be hot. |
25th May 2013 10:53am |
25th May 2013 12:54pm |
There is no smoke nor violent vibration through steering. Took car for a reasonable drive and the smell is coming from front offside wheel. None of wheels were particularly hot. As mentioned, car was only given back by dealer a week ago and they had done some cleaning of front brakes after being asked to specifically check all car's callipers, discs and pads to reassure me they were not in need of near future replacement following other issues I had that called into question the effectiveness of selling main dealer's pre sale multi point inspection.
26th May 2013 5:14am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Just a thought, might it be the fuel burning heater kicking in? Can smell a bit when lit, and will still kick in on these cool mornings to help warm the engine. There is nothing that can't be fixed with a hammer😜😜
26th May 2013 7:30am |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 |
on a SC ? |
26th May 2013 8:08am |
26th May 2013 8:17am |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
My SC has the heater. Optional extra Alcohol and eBay is never a good mix
26th May 2013 10:57am |
Without knowing options, how can you tell it's fitted please? |
26th May 2013 12:23pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35279 |
you will have the timer option on your screen menu Ryan. ... - .- -.
26th May 2013 12:59pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
And a big silver Webastro box with an exhaust on the inner wing... |
26th May 2013 1:02pm |
