Home > Maintenance & Mods (L322) > HELP: Strong squeaking noise from rear suspension (TDV8) |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Probably your lower ball joint, easy way to check is to puncture a very small hole in the rubber and spray some WD40 in the hole with a straw attachment and voila it should shut up immediately, if not, put a blob on PU sealant over the hole to make it water tight and move on to the next... This is not a fix! It will need replacing, just an easy way to diagnose which part...
16th May 2013 8:17am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
defo a 'thursday top tip' that Craig.. ... - .- -.
16th May 2013 8:18am |
Had it on mine as well, went away after the front suspension bushings were replaced (badly worn rubbers). MY 2010 5.0 SC Galway green and sand interior!!
16th May 2013 8:19am |
Often comes and goes with the rain too! Water is a lube after all |
16th May 2013 8:21am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Thank you to our great L322 Guru !
16th May 2013 8:23am |
Here is how to replace the front lower ball joint lads:
16th May 2013 8:25am |
No worries J |
how to is in our wiki as well ..its the same as the RR.net one.. ... - .- -.
16th May 2013 8:28am |
^^^Thanks, I may have found the issue thanks to you both, see EDIT ONE on my original post l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
16th May 2013 8:37am |
I'll place a euro on it, it's the rear lower balljoint |
16th May 2013 8:48am |
16th May 2013 9:19am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I would just change both Present :2008 TDV8 HSE
16th May 2013 10:11am |
^^^Makes sense really.
16th May 2013 10:14am |
