Home > Maintenance & Mods (L322) > Venture cam fuse location?
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
My venture cam isn't charging but works fine when charged on my mates FF.
I'm assuming that a fuse has gone but cannot find reference to it in my vehicle handbook.
Can anyone tell me where to find this fuse?
Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #185125 27th Apr 2013 3:36pm
Discotigger
I don't think the venture cam docking station has a separate fuse, as it's wired through a pcb and into the sat nav unit. Could be that the pcb has fried, but I think that would mean no venture cam picture as well, so I don't think that's the problem.
It could be that the charging pins aren't making proper contact with the camera, this happens with my venture cam and I have to jam a piece of plastic into the side of the docking slot to get the proper alignment for charging.
If you close up the docking port without the venture cam in and turn on the ignition, you should be able to test the pins to see if you're getting any voltage through the pins.
Post #185284 28th Apr 2013 2:13pm
ambulancekidd
Many thanks Discotigger, I'll go check it now. Very Happy The reason women's minds are cleaner than a mans mind is that women change their minds more often!
Post #185755 30th Apr 2013 10:37am
ambulancekidd
Discotigger, you were spot on with your advice, cleaned the contacts & the venturecam started charging right away. I'd spent the last year trying to find a fuse that might have blown lol.
Many thanks...Robert Thumbs Up The reason women's minds are cleaner than a mans mind is that women change their minds more often!
Post #185825 30th Apr 2013 6:01pm
Discotigger
WooHoo!! That's great news.
Glad to have been of assistance!!
Discotigger
Post #185840 30th Apr 2013 7:05pm
