![]() | Home > Maintenance & Mods (L322) > Massive power drain on new battery |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I fitted the larger Bosch 110a battery last summer and all has been well up until recently. However, simply leaving the sidelights on or the rear hatch open is now proving difficult for the battery it seems.
It sounds like the car is possibly staying awake when it should be shutting down. When hoovering it did you manually turn the interior lights off as they will turn on regardless of outside light conditions and the boot interior one stays on for a lot longer as well.
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Failing alternator? Seems quite common on D3s Graham
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35512 ![]() ![]() |
batterys will not recover fully if they go flat , i forget the percentages but a totally flat battery will only recover back to about 95% of original charge and if it gos flat again it will only recover to 95% charge of that 95% state.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Mine was valeted recently for a couple of hours with everything open. Didn't manually switch off anything. No problem. I regularly spend ages packing the boot with all the stuff that my wife seems to want to move from one part of the world to another |
Having any of the doors open means the satnav is operating which from my experience will kill a battery in about 30minutes.
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 ![]() ![]() ![]() |
I've had the exact same problem with a battery I bought last November. I've just had it checked out today at a local battery specialist but they have given it a clean bill of health. No dead cells, it's charged up ok, good cranking rate, etc., etc.. I know the alternator is ok too, as I have temporarily fitted the old battery and it's working a treat - probably didn't need to buy a new one in the first place |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3199 ![]() ![]() |
guys, i know this probably wont stop a major drain, but Dan1984uk put a second little battery in the rear right under floor compartment (where the removable tow hook goes) to supplement his main battery, and as i now have his car, I can tell you I never have any probs at all, even when the lights are left on or the car is left immobile for an extended period.
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
since fitting my new battery I too can leave the car parked up at the airport car park for 2 weeks at a time and have no issues leaving anything open/on during a valet etc. Is your battery under warranty still?
It's got a 5 yr warranty from euro car parts so I'll keep my eye on it and see how it goes. Started this morning no problems after standing for a couple of days so I don't think there's anything majorly wrong |
Flat again - just waiting for the RAC |
Still think you should get the alternator checked... |
I won't rule it out, but it's putting 14v into the battery when it's running, so I don't think it's that. |
