Home > Technical (L322) > Preheater problem
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Preheater problem
Hi have just got my vogue se with a preheater fitted . Getting fumes in car when it's running will have to check exhaust is not loose but what am I looking for ? Where is the heater fitted &should it smoke Bow down any advice most appreciated. Thanks
Post #170534 6th Feb 2013 5:24pm
post moved to a more appropriate section.. ... - .- -.
Post #170537 6th Feb 2013 5:26pm
They can smoke a bit if they havent been used for a while. It should clear after a bit of use.
You should not however get fumes into the cabin. It is unlikely that the exhaust has come adrift but worth a look, you are looking for a small pipe about 1" in dia. It is located near where the passenger front wheel track control arm (rear) connects to the subframe. The burner itself is inside the passenger wing and can be accessed by removing the inner wing liner. This can be done with the car in off road mode with the wheel on, access should be sufficient for a quick look. There is nothing that can't be fixed with a hammer😜😜
Post #170553 6th Feb 2013 6:52pm
Swiftman
thank you
thanks for that seems to have cleared it self .
Post #171761 12th Feb 2013 4:13pm
