Home > Technical (L322) > TDV8 Turbo problems |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
Hi all
4th Feb 2013 7:41pm |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
More likely if its been pottered about the WG was not opening enough and it overboosted as the load increased and went into limp mode One day your life will flash before your eyes......................................make sure yours is worth watching!
4th Feb 2013 7:50pm |
No because it will automatically change up. I asked that to my indie.
I think your right Johnny it needed a good clean out. It seems to be perfect now. 2020 Porsche Panamera Turbo Hybrid (V FAST) 2017 Range Rover Autobiography 5.0 V8 2018 JCW Mini Cooper 2018 Skoda VRS |
4th Feb 2013 7:52pm |
The further up the box you go the more load you apply and the higher the boost it will try and hit which is ltd by the WG. One day your life will flash before your eyes......................................make sure yours is worth watching!
4th Feb 2013 8:00pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Understood Previously..
4th Feb 2013 8:06pm |
Thats why the yoofs always end up blowing their cars up, they keep turning the boost up and get no DET in the lower gears, get em in 5th on a hill and they pink away and melt a piston One day your life will flash before your eyes......................................make sure yours is worth watching!
4th Feb 2013 8:09pm |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 |
Scarey stuff on here sometimes:
4th Feb 2013 8:19pm |
120mph on presumed public roads is one thing
4th Feb 2013 8:26pm |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 |
If you select the gear manually it should stay in that gear and not change up. you push the gear selector to the left to sport then forward for manual selection of the gears on mine. 04 td6. not sure bout the tdv8 but i would imagine it would be able to do this for off roading and heavy towing and the likes where you might want to hold it in a certain gear. '04 td6 se
4th Feb 2013 8:30pm |
It automatically changes up on the revs. if you hit 4500 revs it changes up.Even in Manual 2020 Porsche Panamera Turbo Hybrid (V FAST)
4th Feb 2013 8:36pm |
Must be a safety feature to protect the engine then which would make sense i suppose. aint had mines reving that high so maybe it does change up. will have to try the next time its out now '04 td6 se
4th Feb 2013 8:59pm |
It shuts down to save the engine and turbo. Its quite common if the car is just poodles around. give it a try 2020 Porsche Panamera Turbo Hybrid (V FAST) 2017 Range Rover Autobiography 5.0 V8 2018 JCW Mini Cooper 2018 Skoda VRS |
4th Feb 2013 9:01pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
What's the redline on a TDV8 anyway (and what do they top out at)? Just hold it near without going over in 3rd? On my SC the redline varies depending on gearbox temps, which is a bit annoying :/
4th Feb 2013 9:53pm |
