Home > Maintenance & Mods (L322) > Main Beam LED's
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Main Beam LED's
I'm sure I;ve read this already but can;t find it in a search.
I replaced my Main Beam bulbs with LED's some time ago but get an intermittent "Check mani beam" warning bing and message.
Has anyone replaced main bean with LED's and could they point me in th edirection of a set that will actually work please. Mine do work and are bright but don't want the error. I also get virtually non existent light when the lights are on and I use the "Flash" function.. so I think it;s time to change them. Ash
2016 SDV8 AB
Post #169872 4th Feb 2013 8:43am
you get an error cos the led bulb resistence is to low..you need to wire in a resister or another halogen bulb or get some h8 canbus error free leds.. ... - .- -.
Post #169875 4th Feb 2013 8:53am
Comports, surely they can't be very bright can they? An LED to replace a halogen...?
Post #169879 4th Feb 2013 8:58am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
You'd think that, but if you take a look at Audis with LED headlights they do a good job of dazzling the Censored out of everyone
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #169885 4th Feb 2013 9:12am
Yes but at 10x the cost of xenon headlamps i hardly see eBay bulbs will do the same job......
Post #169896 4th Feb 2013 9:43am
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
My xenons on my old TD6 were far superior to my LEDS on my v8, brighter, better range and without the dead spot in the middle.
Just saying! Thumbs Up
Post #169899 4th Feb 2013 9:48am
comports
Hang on - Loads of folks have changed them over - It's only the Main (full beam) bulbs I'm talking about (I think).
Unless I'm mistaken, I still have the xenons and these are the inner ones (towards the centre of the car).
Now Im confused then.??
Check out this thread - http://www.fullfatrr.com/forum/topic5318.h...ight+bulbs Ash
2016 SDV8 AB
Post #169956 4th Feb 2013 11:59am
you have bi-xenons which supply dip and main, the inner halogen mains are for show and 'flashing'...when i say for show i mean they only get 10volts and are useless against the xenon main...hope that makes sense.. ... - .- -.
Post #169960 4th Feb 2013 12:09pm
comports
It does - Thanks Stan..
So when my display bongs "Check main beam" it suggests an issue with the bi-xenon then... Even though they both work fine.
and I guess I will just live with the non existent flash as well Ash
2016 SDV8 AB
Post #169976 4th Feb 2013 1:10pm
check main beam 'could' be a problem with the bi-xenon but most likely the leds in the inner mains..
you will get flashing with the leds in the inner mains.. ... - .- -.
Post #169981 4th Feb 2013 1:30pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Unless you use Navcoder to sort it out...
Post #169985 4th Feb 2013 1:36pm
