![]() | Home > Technical (L322) > Door mirrors |
Had similar on a 2003 Vogue stock car recently and there is no cure other than live with it or replacement. Local Land Rover Indy took it apart and reported. |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
Hi flipper, I believe there is a fix but its theory at the moment and you also need to be sure your loose mirrors are due to a common failure and not just some loose bolts.......
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35512 ![]() ![]() |
theres a how to in the wiki.. |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
I think I have this problem as well, let us know if the fix works please. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I had this on mine when i got it. Turned out if you remove the cover underneath there are 4 torx screws holding the motor in place. They just needed tightening up and all done. Might be a simple fix. As it happens my pax mirror has just thrown its hand in so needs to be stripped and I'm assuming pins fixing. No one likes driving with a floppy! |
Mines only loose through a small part of its travel. But when I put them in the drivers flys straight back out the pass waits a moment and goes back out. One day your life will flash before your eyes......................................make sure yours is worth watching!
if its loose screws happy days..........if its not then this could be the culprit
flipper Member Since: 31 Dec 2012 Location: United Kingdom Posts: 2 ![]() ![]() |
Thank you to everyone for your response, to my floppy door mirrors. Once the weather improves I shall take advice and report back. However, if the weather doesn't improve, I won't need a Range Rover, I'll need an ark! |
