Home > Technical (L322) > EAS fault code C1A13
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
I've had "suspension fault" come up on the message centre. Checked with my HawkEye and the following came up
"C1A13 pressure does not decrease when venting the gallery, signal plausibility failure".
Have cancelled the fault yesterday, after about 100 miles it has returned. Has anyone else had this happen and if so what needed to be done to cure it.
Forgot to mention 06MY 4.2 SC
Stewart
Post #158877 20th Dec 2012 9:15pm
Brian GOG
United Kingdom 2002 Range Rover HSE Td6 Epsom Green
Hi Stewart
You've got a compressor fault, there is a bulletin that details changing a filter and receiver dryer (I don't know the bulletin number of the top of my head - it will be on here somewhere). I've had mixed results with this repair but if you are doing it yourself it's worth a try first.
There is also a new type of compressor available from LR it's an AMK instead of a Hitachi one. Eatrly signs from the ones I've fitted seem to be good. It feels more robust and is quieter. It does need a software update doing if you go for this option.
All the best, Merry Christmas
Brian
Green Oval
Post #158914 20th Dec 2012 10:13pm
SGW
Hi Brian,
Thank you for your quick reply, I will check both items before going any further.
Compliments of the season to you.
Stewart.
Post #158916 20th Dec 2012 10:28pm
