![]() | Home > Technical (L322) > Coolant leak |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
could it be coolant? the gearbox oil should be a honey color if new and prob black if it hasnt been change in its life. the V8 use either red/pink/orange coolant or blue/green. if its by the bell housing could be one of the hose's at the back of the engine running down. i had a similar issue with mine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Could well be. Coolant doesn't evaporate and leaves a patch on the floor which looks like oil ![]() |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
Coolant manifold gaskets leaking. I've just replaced mine for the same reason. MY2010 TDV8 Vogue Ipanema Sand
SparkyPhil Member Since: 29 Oct 2011 Location: Staffs Posts: 59 ![]() ![]() ![]() |
Just been out to check coolant and I don't seem to have lost any but it was still slightly warm. It is red/pink in colour but by dipping my finger in the header tank I couldn't really tell if the texture was the same also I have cardboard under the car and the coolant/oil was sitting on top and had not been absorbed, which makes me think it is oil.
Do the taste test, if it's sweet and sticky it is antifreeze |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Just about to say, have a taste of it.
Well thanks for the replies, I have placed a washing up bowl under the car so will be tasting whatever has fallen into the bowl tomorrow, but it is totally dry at the moment.
Well under the car this morning to taste whatever was in the bowl and it was empty |
Have you had the air con on ? Could just be water drips from that (slightly contaminated). This drip is perfectly normal!
Quick update: It seems that a coolant hose which is something to do with the lpg system, is actually a rubber gas hose and with warm coolant being passed through it has gone brittle and started to crack, there is also a slight leak on the thermostat housing, I am a bit p****d that the wrong hose was fitted in the first place but it has been rectified now. I also had a level 2 service done a few weeks ago and none of this was noticed? Thanks for all the replies.
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
glad you sorted |
You should get the rave and if you have the tjne and inclination, you can do your own maintainance then you know its dine propperly . Save your self 90 pounds plus per hour also . MY2010 TDV8 Vogue Ipanema Sand
I have still got a water leak |
Update:
