Home > Technical (L322) > Won't start, help.!!! |
Worth getting the alternator checked to avoid ruining another battery... |
26th Nov 2012 8:15am |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 |
hello i had the same problem, relay under the ignition key part bmw 61326901961 |
27th Nov 2012 3:44pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
Expensive for part? Easy to change?
27th Nov 2012 3:56pm |
I've got the original, you never know which bmw over the years may have modified the original replacement ... cost 70 euro, but there is also competition (valeo) very simple work .... |
27th Nov 2012 4:02pm |
The weird thing is the key turns fine steering wheel unlocks..I hear an electric clicking sound at the ignition.. |
27th Nov 2012 4:06pm |
sometimes feels a beep and a zzzzzzz near the gear selector .... |
27th Nov 2012 4:09pm |
27th Nov 2012 4:12pm |
This sounds spot on, I just got the car started before tow company came out.ok this may sound like a ridiculous question but can I just spray some contact cleaner into the ignition or will that f k something up ..just to try it . |
27th Nov 2012 5:28pm |
I tried, just that you can not do get the product into the ignition, the contacts are on the side, you have to remove the butt of the lock
27th Nov 2012 5:41pm |
From searching the forum I have nailed the intermittent starting problem down to 2 possibilities:-
27th Nov 2012 10:01pm |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 |
Hi Lolo
4th Dec 2012 4:09pm |
Hi Patrick,
4th Dec 2012 5:01pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Does sound like the same problem I had, not too bad a job to do |
4th Dec 2012 6:04pm |
Hi Lolo
4th Dec 2012 6:21pm |
