Home > Technical (L322) > Won't start, help.!!! |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
It sounds like a classic battery fault. The cold weather will really show it up now. I had exactly the same problem. If there was a fault with the starter no amount of jumping would start it!
25th Nov 2012 8:43pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35312 |
this also sounds like anew battery is required.. ... - .- -.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3976 |
If your car starts with a jump start there's nothing wrong with your starter.
25th Nov 2012 8:45pm |
Glm Member Since: 09 Dec 2011 Location: Manchester Posts: 105 |
Cheers for advice guys ! Not been on for a while but knew when needed help would come b4 getting recovery out to dealers ! Current tdv8 range vogue 07 |
25th Nov 2012 8:47pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
Ok hopefully as simples as that..! It's a shame I don't know how old the battery is though. Will keep u posted.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3156 |
Make sure both the connections to the battery poles is tight. Even a little looseness can result in a bad connection. I once lost all power and it was a loose pole connection. |
25th Nov 2012 9:49pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Lol just got a Bosch S5 for £113 plus 5% cash back through quidco. Do they have eurocarparts there? They will deliver for £9.50 [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
25th Nov 2012 10:26pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Der. That light's there for a reason. Graham ____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
25th Nov 2012 10:27pm |
I know it's there for a reason, and I always wait for it to go off myself but just wondering if any harm can be done or if its an FYI type light that's telling u the glow plugs are heating up or whatever. |
25th Nov 2012 11:01pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
Lolo,
25th Nov 2012 11:28pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Halford s do them Lolo that's where I got mine 5 year warranty.hope you get sorted. Present :2008 TDV8 HSE
25th Nov 2012 11:33pm |
25th Nov 2012 11:43pm |
Ah thanks googsy ill call them tomo. |
25th Nov 2012 11:44pm |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
bought a Bosch s5 110Ah 920cca job in halfords drogheda one week ago.it was a tasty 189 euro but the 5 year warranty helps and it starts the v8 instantly.Money well spent.they will test the battery before you leave the store and will fit it if you want.......
26th Nov 2012 12:09am |
