Home > Maintenance & Mods (L322) > Looking for someone to stop the water ingress |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
What, where is getting wet? Previously..
23rd Nov 2012 9:11pm |
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 |
Sat nav and amp in the rear |
23rd Nov 2012 9:12pm |
Yip, common problem. Have you fitted the official water shedder? Previously..
23rd Nov 2012 9:13pm |
It's got a plastic cover on, but I want to get it fixed if possible |
23rd Nov 2012 9:14pm |
It's crazy that the landrover fix is just to put a plastic bag over it! I lost my Bluetooth module with the same problem. I never tracked down the source of the leak. Even wondered if it was condensation drips as there must be a bit of heat in there with all the kit, the weather turns cold, etc etc. I wonder if vents in the access hatch would help?? There's an idea....... Previously..
23rd Nov 2012 9:21pm |
It's more than condensation, there was bad rain last night and plenty of water on the pastic today, sometimes I think I'd be better with a stand alone head unit. |
23rd Nov 2012 9:30pm |
This will sort it
23rd Nov 2012 9:58pm |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
^Not funny. My garage actually recommended that to me.
23rd Nov 2012 10:20pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Check the boot seal first, take it off and look for wear holes.
24th Nov 2012 12:04am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
@ mrd1990
24th Nov 2012 1:09am |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 |
I had the same problem mate, I stripped it all out and got six inch sticky lead flashing and gutter seal and shaped it around the void above the electronics. Havn't got any pics sorry. if you pm your number to me i may be able to explain more clearly. So far touch wood or cloth its been ok. gone fishin' |
24th Nov 2012 8:18am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3141 |
It is probably caused by blocked drain holes, most likely the sunroof. There is oodles of comment here and some pictures, I think the solution was found to be a long rotating wire into the sunroof drain hole or stg. Search should find it. |
24th Nov 2012 8:26am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
@cleughy
24th Nov 2012 9:01am |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 |
For what it costs replace the boot seal with a new one to be absolutely sure. Fixed 2 different RR's when I have had this problem in the past. I hate water in cars !! |
24th Nov 2012 10:52am |
