![]() | Home > Technical (L322) > Radiator cleaner |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
I used Holts Radflush a good few years ago. Cleaned out lots or crud from my mates Camel Trophy Disco....... Think it's in 2 parts now (Radflush, not my mates Disco !!)
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Yes I think it will. If you look down behind the rad you will see some smaller gauge hoses. These are the ones used for the gearbox cooling section. There is a little rad (trans cooler) at the bottom left. This is a coolant/trans fluid cooler. The new rad should enable the coolant in the smaller hoses to be cooler and help. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Many thanks for the pic.
No problem, this is good info for me as well. What happens after the flush, I think it is best to replace all the coolant and put new in ??? MY 2010 5.0 SC Galway green and sand interior!!
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
After the flush, use NEW coolant. Jim
Most Transmission Specialists have a pressurised machine to properly flush the radiator & Oil Cooler plus pipes etc. Worth getting a quote for a proper flush. |
If you would live in 1st world countries yes, but here I wouldn't risk it. Hence my question. Getting coolant is not an issue here, getting flushing done is a different matter. Even getting radiator flush will be hard (might have to bring some back from Europe on the next trip. MY 2010 5.0 SC Galway green and sand interior!!
oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51 ![]() ![]() ![]() |
Is there a certain Land Rover coolant that should be used for topping up the level, or will a general purpose anti-freeze be ok. |
Depends on whats already in it really |
doh FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
I will get some in Holland when I am going over there in a few weeks time and send it back in the airfreight. The injector cleaner I can buy here is STP and seems to be the original stuff so I am not worried about that but haven't seen (nor looked for to be honest) radiator flush.
