Home > Technical (L322) > Replacing Coolant Manifold
Nickandtacita
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Hi, has anyone ever had the coolant manifold replaced (mine is cracked and leaking) and if so how long/ expensive is it likely to be
Thanks
Post #147298 21st Oct 2012 1:56pm
Rear one on a V8? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #147306 21st Oct 2012 3:12pm
Nickandtacita
Yes thats the one, lower fixing lug is missing, someone has botched up a repair with Sticky stuff, but the casting is now leaking
Post #147307 21st Oct 2012 3:34pm
It's only 3 holts per side. Quite straight forward but space and access is the issue. If you removed the cabin filter and the PCV valve off the back of the inlet plenum then you would prob have better access. Then you would need to refill the coolant system. Not a hard job just a fidley ball ache of a job. Might be easier for an Indy who's done it a few times. How many miles? Could be worth doing the water pump while your at it. Other side of engine but if your disturbing the front to back pipes would make it easier as you wouldn't have to worry about the seals. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #147331 21st Oct 2012 6:45pm
Nickandtacita
Thanks for the advice Rob, I will get it booked in tomorrow, looks very fiddly to me, got as far as covers off and located the leak, but then put it back together
It's done 66000 miles allegedly
Post #147339 21st Oct 2012 7:04pm
Not sure if you would want to but V8's are prone to water pump failure. There only £45-70 so not hugely expensive so could be worth looking into to save it happening at the side of the road. I've stripped the top of the engine down to get to the valey pan and put a load of photos on here somewhere. Have a dig round and have a look at the pics and you will see what your looking at. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #147354 21st Oct 2012 8:29pm
Nickandtacita
Ok will do, thanks
Post #147359 21st Oct 2012 8:58pm
