Home > Technical (L322) > Extra intercooler |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Those of us who own a TD6 will be aware that the lh side of the engine bay on RHD cars has a bit of space.
21st Sep 2012 12:54am |
TBH an IC needs a good flow of air to cool it down.
21st Sep 2012 9:16am |
While cooling the charge is obviously never bad, additional gains by simply adding an intercooler will be marginal at best - even if the IC lowers the temp significantly. You'll need a custom (bespoke) tuning map to take advantage of the cooler charge and make a significant difference. And you'll need to assure good cooling (large surface area IC with good airflow) w/o significantly increasing the volume of the intake air between the turbo and the cyl head. Both will not be inexpensive to do properly.
21st Sep 2012 10:35am |
Also if temps stay pretty warm where you are stick one infront of the section of rad that cools the transmisson oil as well to help that live a little longer
21st Sep 2012 10:51am |
I keep forgetting that bit It may help keep the fluid going back into the box that bit cooler though and make it last longer. its only really designed to get the oil warmer quicker and i think its been mentioned on here before its very tight on temp limits and if the engine is running very hot but not overheating the gbox fluid is out of range and will begin to degrade? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
21st Sep 2012 11:57am |
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 |
I carried out an improvement on my old Discovery by adding a second intercooler & the difference it made was impressive. I had more oomph when towing our caravan uphill especially on long inclines & it improved the fuel economy by 2 or 3 mpg, all of this was done without tweaking the fuel pump as my Discovery was an auto & had an early electronic fuel delivery setup which I didn't want to disturb.
21st Sep 2012 5:17pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
Simply chipping or turning up the fuelling will massively increase your exhaust gas temperatures (EGT's), and high EGT's eventually take your head gasket out or worse.
21st Sep 2012 5:29pm |
Or aquamist to reduce EGT's as well.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
21st Sep 2012 7:29pm |
Oh yes - I remember - and I need to remember to read through posts completely before opening my virtual yap... Not an easy solution, then. One route I had wanted to go with my P38 was to have an IC built to my specs. I had wanted to go down from the original IC to get larger. Problem is, on the L322 there is hardly any direction to go from a stock location. IC cores can be bought in various sizes, cut to the exact size needed and a competent radiator shop can make appropriate end caps and weld them on. If you use the end caps from your original IC as a starting point, you'll have the proper hose fittings and possibly mounting surfaces to boot. Just how to get larger, tho... Interesting site w/good info too http://www.bellintercoolers.com/
Or just go to a reputable re-mapper... RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
21st Sep 2012 7:39pm |
