![]() | Home > Maintenance & Mods (L322) > Central locking fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
re -check the connections.. ... - .- -.
Remove the connector and try to clean as much as you can, preferably with clean compressed air. Also if possible use electrical contact cleaner spray, that is supposed to be better than WD-40. (I smuggled a can to here as I can not get it here, the contact cleaner that is, WD-40 is easy to get here). MY 2010 5.0 SC Galway green and sand interior!!
Shaun Member Since: 02 Jul 2010 Location: Hull Posts: 58 ![]() ![]() ![]() |
Door card is now refitted with door shut and locked. |
Door unlocked today so i have removed door card, cleaned contacts and sprayed some more WD40. Module removed from door card and plugged back in, will not be refitting door card until i am confident it will unlock. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
A good tip is to spray the door with a hose pipe for a good 10mins... Meaning if the weather is too hot, it will cool it... If there's an earth fault, the water normally cures this too (well enough to get it to open once so you can remove the door card to inspect)
