Home > Maintenance & Mods (L322) > B pillar black finisher |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7794 |
Are the B pillars not actually the window surrounds ?
21st Jul 2012 1:04pm |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 231 |
I have the same appearance but on the vertical bit in the picture. I decided to leave it in place and rubbed it down with1200 grit wet and dry, then sprayed it with satin black. Looks perfect again! |
21st Jul 2012 5:57pm |
I'm wondering whether that might be easier with mine to be honest.
21st Jul 2012 6:53pm |
I found an example of the trim in various places - only £20 but to be honest, although the finish of the satin spray isn't as smooth as the original, it does refresh the appearance of the panel, and is a good value for money bit of maintenance. |
21st Jul 2012 10:02pm |
As the little black strip at the bottom of the window seems to be about £30 odd, I didn't even ask how much for the window surround.
21st Jul 2012 10:29pm |
ollielloyd Member Since: 09 Oct 2012 Location: United Kingdom Posts: 120 |
15th Oct 2012 9:10pm |
Not done it, but I believe its screwed on from behind, ie you have to remove the door card and seal to get to the screws ........... 2011 Range Rover Vogue SE 4.4 TDV8
15th Oct 2012 10:18pm |
