Home > Technical (L322) > Is this normal suspension behaviour?
Page 1 of 3 123>
Tuts
My suspension appeared to do something unusual today (although it may be normal and I've just never noticed it before!)
Basically I put the key in the ignition and turned it to II (warning lights on but engine off) and I noticed the front of the car raised up (engine still off) . Never noticed this before? Is this normal? The suspension changes between the four settings as it should manually and automatically , on this occasion I think it was previously parked up in access mode - someone please tell me somethings not gonna go pop! if this is completely normal then please excuse the noob question ! 2003 Vogue 4.4 V8 Java Black
Post #127797 26th Jun 2012 5:48pm
Mine does this on occasion, sometime front sometimes back, sometimes a little whirr from the compressor. No fault codes from diagnostics though, guess it just gets in a pickle and has to sort itself out. .
Post #127798 26th Jun 2012 5:50pm
Tuts
Phew thanks - I do get worried when I see these ...(quirky?) things that the car does 2003 Vogue 4.4 V8 Java Black
Post #127799 26th Jun 2012 5:57pm
Does it at traffic lights too sometimes, which I quite like, because no-one elses car does it.... .
Post #127825 26th Jun 2012 7:17pm
Muddywheels
My RRS does this sometimes - noticed it when pulling up at diesel pumps mainly Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Still hoping for a S2 one day!
Post #127826 26th Jun 2012 7:21pm
Same here mine does it as well when i come to stop at lights , only now and again it does it tho ... Thumbs Up
Post #127832 26th Jun 2012 7:42pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
If you leave it parked on uneven ground, it will try to level itself out - may be why it resets part (i.e. the front only) when you return to it?
Post #127845 26th Jun 2012 8:25pm
ebajema
Mine does it as well, mostly when I have been using with access height. MY 2010 5.0 SC Galway green and sand interior!!
Post #127846 26th Jun 2012 8:45pm
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
It is just the suspension leveling itself out....
If I leave mine in the sun, the warmth makes the air expand rising the vehicle a tad, when I get in and close the door, this has the effect of commanding a relevel from the system...and she drops a tad....
Overnight she will relevel every 6 hours to maintain level (it will ower itself to its lowest corner - never upwards - until you open and close the door to command a relevel to compensate for your bodyweight)
The relevel at traffic lights is to compenstate for the nose down due to braking, it just pops the nose back up again....this then triggers a check check for 4 corner leveling, hence the slight adjustments while waiting at the lights.
Post #127882 26th Jun 2012 9:53pm
Tuts
that makes sense as my driveway is slightly downhill, i'm just glad it means its not Censored ! Thumbs Up 2003 Vogue 4.4 V8 Java Black
Post #127883 26th Jun 2012 9:54pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I find that funny too, suddenly the car goes up an inch or two, and everyone is wondering what the hell is happening.. I just have to look down on all those around me without randomly adjusting odd suspension abilities. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #127894 26th Jun 2012 11:13pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
First sign for the defect pressure sensor in the silver air-tank under the right side of the underbody..., and also for the compressor pressure under 13,7 atü...., because the ECU, the sensor and the front ventil work together only with full pressure
regards from germany
Post #127900 27th Jun 2012 5:48am
Aren't you a ray of sunshine this morning. Rolling with laughter
Do you work for Wabco meerbusch? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127904 27th Jun 2012 6:11am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Its normal!! ( for a range rover) Thank god for that i was starting to wonder about it, you do get the odd funny look at traffic lights when it does it! Whistle Mine was a blue one! Smile
Post #127906 27th Jun 2012 7:54am
ebajema
It is quite a lot of fun playing with the suspension height. I now do it on a daily basis for my drive to/from work as the rainy season creates some deep puddles with all kinds of crap in them. I look at all the "poor" sedans scraping through and I just glide through at offroad height ! And access height is also great for the kids and SWMBO getting in and out. And the random adjustment/re-levelling is just quirky. MY 2010 5.0 SC Galway green and sand interior!!
Post #127907 27th Jun 2012 8:17am
Page 1 of 3 123>
