Home > Maintenance & Mods (L322) > Cracked windscreen
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
Cracked windscreen
Hiya,
My shiny new RR has got a cracked windscreen. Sad
It's only a small crack and normally I'd just get it repaired, but it's got the heated windscreen and rain sensors and leather trip and all that gubbins, so I'm not sure it's that simple!
So what I want to know is - can the screen be repaired? And if not, is replacement a simple, straightforward task? I.e., will everything work on it afterwards? My insurers have appointed a company to do whichever job I choose, and the guy is bringing a new windscreen in case that's what I need.
Thanks in advance! Thumbs Up
Post #124499 31st May 2012 12:13pm
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I would rather have a new windscreen; but make sure it is OEM and make sure they take their time in fitting it indoors. I remember a friends car which developed more problems than it solved - some horrible wind noises are not uncommon on FFRRs either after a repair.
ETA: Is it a crack or a chip? If it is a chip it can be repaired. The rain sensor is at the top of the windscreen but the heated element will not work for that small section of screen if repaired.
Post #124501 31st May 2012 12:35pm
Squirrel
Ah, now there's the problem - there is no indoors here that they can use. They're one of these mobile fitters. Not sure I like the idea of extra problems caused by the windscreen, just for a little crack.
It's definitely a crack - there's a tiny chip where the stone has hit the screen, and the crack has spread out on either side from the chip. I don't mind that bit of the heated screen not working - it's on the passenger side, over towards the tax disc, so well out of my immediate field of vision. Just as long as the most of heating element will work, I'll be happy.
Looks like a repair then. Thanks for your help! Smile
Post #124503 31st May 2012 12:41pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
That sound like just a bad chip you should be able to get it repaired by autoglass etc I have had a couple dine in the past with good results. Like EVO says you might just loose element in that bit. Pity you didnt see it when you bought the car and got dealer to sort it.
PS if he replaces it make sure he reconnects everything they left the rain sensor/ auto headlight module unplugged on mine Mine was a blue one! Smile
Post #124508 31st May 2012 1:27pm
Squirrel
The dealer swears it wasn't there when they did the PDI before the car was delivered. But he drove it across to my place FOC, so if it happened on that trip it would be mean of me to take him to task over it! Especially when a repair will cost me nothing anyway. I know it didn't happen while I've been driving, because I'd have noticed. There's a vague possibility that some muppet will have lobbed a rock at it, I suppose, but I can't see why they'd have done that - it's only been parked on the drive since I got it.
Ah well - one of those things! If it'd been on my side, I'd have noticed - but because it's right over on the nearside, I only happened to notice it yesterday when I was looking for something.
Thanks for the info on the reconnection - though I'm thinking that if he wants to replace the whole windscreen, I might just send him away and take it down to LR as long as my insurers agree to it. (Well hey, I can dream. Wink )
Post #124511 31st May 2012 1:41pm
edward.barry
Ireland 2005 Range Rover Vogue Td6 Buckingham Blue
Hi, I concur, if its a chip, a repair sounds like the better option. I has a similar issue a few weeks back and the repair took 30 minutes and is almost invisable. 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
Current fleet
2005 RR td6
1997 300 Discovery
2005 Subaru Legacy Outback (the wife's)
1981 2.5 Opel Commodore
Post #124512 31st May 2012 1:42pm
Andy3681
I think the dealer will just send it Autoglass etc I dont think its somthing they do in house but I have seen a tread on here about how many screen options there are!!
Anyway hope it gets sorted and is the last of your problems Whistle Mine was a blue one! Smile
Post #124516 31st May 2012 2:27pm
duka
2010 Range Rover Autobiography 4.4 V8 Alaska White
Auto glass vacuum repair works well, subject to crack size. It only takes 5 minutes.
I understand if it's anew car you'd want a new screen, but if it's not fitted correctly.....
Post #124525 31st May 2012 4:03pm
Squirrel
Thanks guys, I feel much better now about just getting it repaired. I was just worried that a repair would stop the entire heated screen working. (Even if it might, please don't post to tell me that!!)
I'm just going through the car bit by bit every evening, and tonight's exploration took me through the boot. No removable towbar (didn't want one anyway, so that's no problem), no warning triangle, no toolkit. But there is a very nice spare with a new tyre on it, and most of a Panavise portable vice - but not the jaws, for some bizarre reason. And fortunately, the key for the locking wheel nuts is still there!
It's a good car, this. Normally I'm bored with exploring the various bits and pieces within a couple of days, but with this one I haven't finished exploring yet, so I certainly haven't had time to get bored with it. Rolling with laughter
Post #124549 31st May 2012 5:35pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
I got a stone chip in mine & had the entire glass replaced.
The heater elements are most likely broken if the glass is cracked.
When I talked to the insurance company, I mentioned the heated glass.
We agreed there was no way for me to see if the heater wires were broken or not, so replacement was the solution.
Took the guy about 90 minutes in my driveway. It was a nice day, so he just did it outside.
$1300, covered 100% by insurance; which is not the same as "it didn't cost me anything". Jim
2000 NAS HSE
2005 NAS HSE
Post #124569 31st May 2012 7:13pm
Squirrel
Well, this is my quandary. There's no way to tell now for several months whether the heating elements are still working or not. But then again, I don't much want the guy to end up damaging the leather trim or the electrics either.
I think on balance, I'll go for the repair if I can. (The crack may be too big for that...) If the electrics don't work - well, I've only just bought the car and my last car didn't even have a heated windscreen, so I can live with having to scrape the thing clean on icy mornings. The only problem being that I can't reach the top of the RR windscreen. Very Happy
Post #124583 31st May 2012 8:46pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Turn the elements on and wait for a min or two, then you can feel which areas of the screen are warm and which are cool.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #124588 31st May 2012 9:16pm
Squirrel
Oh. I never thought of that. Very Happy I guess I should do this before I let the repairman leave??
Post #124589 31st May 2012 9:19pm
Put a cup of coffee on the dash near the crack/chip and wait for it to steam up then put the screen on and it will be obvious if it works then Thumbs Up
Craig Cool
Post #124601 31st May 2012 10:26pm
...............or put cling film on the outside and when it shrivels up you know its working.... ... - .- -.
Post #124639 1st Jun 2012 10:56am
