Home > Technical (L322) > Green Trailer light when towing
mzplcg
Just hooked up the tintent (caravan) having had the 7 pin socket replaced with a 13 pin one for the new van and the green trailer light is on all the time. On my old D3 this used to flash with the indicators. Can anyone confirm if this is normal please?
Genuine LR 13 pin wiring kit used. Replaced genuine LR 7 pin kit. Nothing else done. Indicators work fine on the van and flash in time with the car as you would expect.
Thanks in advance
Dom
Post #21346 30th Jun 2010 10:23pm
dan_uk_1984
This thing has a mind of its own. My trailer light never comes on, although all the lights work fine....
Post #21351 30th Jun 2010 11:37pm
specman
Scotland 2016 Range Rover Vogue SE SDV8 Aruba
I towed my van two weeks ago for the first time, previously it had been a Disco 2 with the syncrhonised green trailer light flashing in time with the indicators, however my FFRR just had the constant green trailer light.
It has just been changed from genuine LR single electrics to the genuine kit from single electrics to 12n & 12s electrics, yet to try it out though.
Post #21353 1st Jul 2010 6:35am
The answer is yes ,the green light should be permanently on to confirm you have trailer electrics connected Thumbs Up 2008 MY Supercharged
Post #21354 1st Jul 2010 7:26am
mzplcg
Thank you Gentlemen, what a fine and helpful bunch you all are Thumbs Up
Post #21358 1st Jul 2010 8:12am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I have been towing with mine for nearly five years and never knew there was a green light.
Genuine LR tow kit, suspension locked light comes on but no green light.
Where is it?
Ian
Post #23015 23rd Jul 2010 7:59am
Fox
On my defender, it only came on when I indicated left or right. Shocked
Post #23016 23rd Jul 2010 8:17am
Iknow this is old, but has anyone got any other points?
My little green trailer light stays on all the time when the trailer is attached, the hand book says it should flash.
But most evidence says it stays on. Has anyone got one with a factory installed socket to compare against? Mine has the genuine wiring from landy dealer programmed with autologic by local reputable indy.
Just wondering if he did it right? There is nothing that can't be fixed with a hammer😜😜
Post #116869 9th Apr 2012 9:31am
Mine has trailer electrics and i tow often... My green light does not stay on on any of my past three FF's! Why/what did the indy do? Mine has always been plug & play...
Craig Thumbs Up
Post #116873 9th Apr 2012 9:44am
supershuttle
Just to join the fun - mine stays on all the time when I have the light board of my bike rack connected.
It aslo tells me to check trailer lights ever time I take the key out - so I do - but they're alway fine. Geoff
Post #116877 9th Apr 2012 10:04am
Johnte
Mine was a Westfalia 'plug n play' and does stay on. But I do use a converter, to convert from 13pin (I'm not sure if that makes ant difference)
(Also tells me to 'check lights' every time) Confused
Post #116878 9th Apr 2012 10:06am
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
Yes mine is on with electrics plugged in and off when not plugged in..... something works then!! 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #116892 9th Apr 2012 10:36am
AMD
On my 2007MY S/C the green trailer light stayed on when towing. In my 2011MY no light at all when towing!? Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #116916 9th Apr 2012 12:13pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Pretty sure handbook claims trailer light ON when hooked up. It's because you'd never notice otherwise Wink Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #116920 9th Apr 2012 12:24pm
As far as i know, and have been told by both the indy and the main agent, the land rocer kit is not plug and play, it will work but requires programming to activate the shut off for the parking sensors and ride height. Aparently.
All the lights work fine and the parking sensors on the back do cut off. Not sure about the ride height, tricky to check, am i correct in assuming that as it doesnt flash with the indicators i will get an error message when a bulb goes.
Have checked the book and it does say flash in the dashboard lights section, maybe they havent updated the book as it also list a check trailer lights message and there would be little point in having a flashing light and a message. there seems to be a consensus for it staying on There is nothing that can't be fixed with a hammer😜😜
Post #116923 9th Apr 2012 12:36pm
