Home > Technical (L322) > GM kickdown stutter |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 979 |
You have a TD6(?) - so it has the GM rather than the ZF transmission.
28th Mar 2012 11:00am |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Whoops - no the engine was off (and yes it's a GM - title edited now)!
28th Mar 2012 1:45pm |
No problem Both the ZF & GM transmission fluid levels are set with the engine (and therefore the transmission oil pump) running so that the torque converter, oil cooler and its pipes are all full of fluid and not draining back down into the sump. In addition you should also move the gear selector lever through each of its positions (holding for 3 seconds in each) and then back to Park just before the final level is set to ensure that the valve block galleries are also full. You already know about the importance of the fluid temperature.
28th Mar 2012 3:11pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
@ RRPhil
28th Mar 2012 4:53pm |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 |
Thinking of getting my gearbox flushed,
28th Mar 2012 9:17pm |
@ Joe90
28th Mar 2012 9:21pm |
Actually wonder if rrphil can do this, as I am in Blackburn
28th Mar 2012 9:24pm |
Sal,
28th Mar 2012 9:45pm |
Hi phil,
28th Mar 2012 9:53pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1666 |
Guys, you can edit the wiki yourself to correct or add information - that's the whole point |
29th Mar 2012 7:53am |
I tried Martin - but it says that the topic is locked. The text that I wanted to add (given Phil's advice) was:
29th Mar 2012 9:30am |
For wiki permissions see here: http://www.fullfatrr.com/wiki/Help:Contents
29th Mar 2012 9:42am |
Joined the group, logged out & in (just in case) but "How to change Td6 automatic gearbox oil" still locked in the wiki |
29th Mar 2012 11:01am |
Right - that's because it's a link to a forum thread, not a wiki page.. |
29th Mar 2012 11:03am |
