Home > Maintenance & Mods (L322) > condensation in rear lights
daveo
i have been suffering condensation in my rear lights in the last few month's, some times they are streaming..
so i decided to take them out to see why this is happening, on first inspection i could not see any reason why or where the water has got in.
i only found one of the rubber vents folded over, may be got caught when fitting
it seems like the condensation escalates and goes from worse to worse, there seems to be an outer and inner clear plastic and the water is draw up from the bottom by capillary then forms as drop as it runs back down to the bottom of the light.
firstly i drained what water i could get out via the main vent
then came out the hair dryer on low and left running for 30 min moving around the light, the prob is its a sealed unit and you cant get into main part of the light.
after about an hour it has all gone but leave it to cool down as if you take it out side being hotter the out side it will condensate with what moisture is in the air..
left to cool down and all is well
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #58998 5th Apr 2011 10:31pm
pretlove
i had this with one of mine and once i fitted it to the car it started all over again ...its as if the condensation can get in but cant escape ....so with mine i drilled a 2.5mm hole on the inside of the light from behind where your red reflector is making sure not to press to hard as i didnt want to go right through the lense and the problem has now gone away, and from the outside you cant even notice it unless you look very hard .... Thumbs Up
 "RANGEISM WILL NOT BE TOLERATED"
Post #59005 5th Apr 2011 11:53pm
i took a slightly easier route in drilling a very small hole on the bottom right of the near side and bottom left on the off side on the outside with the light units still in place...the effect wasnt immediate but gradually the condensation has gone... ... - .- -.
Post #59013 6th Apr 2011 8:07am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Drilling a small hole from the bottom worked for me too Thumbs Up 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #59018 6th Apr 2011 9:34am
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
and me Thumbs Up
Post #59026 6th Apr 2011 10:46am
and me also.. Thumbs Up ... - .- -.
Post #59036 6th Apr 2011 12:46pm
pretlove
drilling a hole seems to be the way forward Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #59050 6th Apr 2011 1:54pm
daveo
so have you all drilled the hole on the outside or inside of the light V8 facelift Range Rover Autobiography 22" wheels.
Post #59180 6th Apr 2011 10:01pm
Parking it in the garage fixed mine.
Post #59196 7th Apr 2011 7:02am
hope this helps dave..
Post #59202 7th Apr 2011 8:18am
benjj
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
I just drilled a hole in my OSR light too, exactly the same as Stan's. It had a good inch of water in the light so will be interested to see if this cures it.
I have resigned myself to buying a new light anyway if it doesn't but i am hopeful!
Post #111052 5th Mar 2012 7:26pm
most of the time mine are ok, but occasionally they do mist up but clear fairly quickly... ... - .- -.
Post #111059 5th Mar 2012 7:40pm
If you take the lights off you can drill 3mm holes in each of the bottom corners, on the bottom edge, where you can't see them. This clears the condensation as well. Wink Smile
Post #111069 5th Mar 2012 8:05pm
Googsy
Mine do this too and it bugs me. Thanks another easy fix chaps Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #111073 5th Mar 2012 8:12pm
pretlove
As my pic shows I drilled the hole in the back of the light that way you can't see it and it's a lot better for when you are washing the car saves you getting more water in it with the hose Thumbs Up
Touch wood ....my new s/c lights haven't suffered from this problem "RANGEISM WILL NOT BE TOLERATED"
Post #111113 6th Mar 2012 12:08am
