Home > In Car Electronics (L322) > DVN-E39 with Reverse Camera !!!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
i think when you connect the camera to the reverse light feed and select reverse the camera will have power and the video will show up on the screen.. |
27th Nov 2011 5:35pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
on a factory set up it would be a ground to pin 17 on the tv module, this would switch the monitor to av and then show the camera. V8 facelift Range Rover Autobiography 22" wheels.
27th Nov 2011 5:38pm |
andy vash Member Since: 15 Aug 2011 Location: uk Posts: 13 |
I’m assuming this is how it works but I cannot identify which wire to connect up on the back of the Dynavin |
27th Nov 2011 5:41pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Hi Andy - Bringing up an old post here but..
18th Feb 2012 6:32pm |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
ill b following this post as its something im considering as well, luv the 04 vogue but the non touch screen is annoying |
18th Feb 2012 6:55pm |
Did a bit more digging last night on this. It seems the Dynavin E46 (D99) and the Dynavin E39A are both direct replacements for factory units. (i.e. plug and play)
19th Feb 2012 8:26am |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
Green wire on dynavin is the reverse signal |
19th Feb 2012 11:42am |
Well I just answered my post - Speaking with Dynavin - none of the systems they make (DVN E46 or DVN-E39) will integrate into my car as I have DSP. This would involve ripping out the whole amp and cabling and a complete re wire to each speaker with a new amp etc....
20th Feb 2012 1:10pm |
