Home > In Car Electronics (L322) > Sat Nav Screen Too Dim
whoami
2008 Range Rover Vogue TDV8 Zermatt Silver
As above on a 2008 Vogue.
Has been fine for the last 2 years but suddenly has gone dim.
It's still useable but seems to be getting slowly worse.
Any ideas?
Cheers.
Post #107005 12th Feb 2012 8:49pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
On the odd occasion mine has had a mind of its own and displays dimmer or brighter than normal. But it's always fine on the next drive. I'm guessing there's an ambient light sensor which is supposed to adjust the brightness accordingly, but sometimes it gets it horribly wrong.
If you've not done so already, check the screen brightness in the settings menu, and check the dash board light dimmer is not tuned all the way down.
Gone - Range Rover Supercharged 2006
Post #107010 12th Feb 2012 9:07pm
whoami
Hi Justin.
Already checked the brightness settings in the menu and the dashboard dimming. Both okay.
Do you know where the sensor is?
Post #107018 12th Feb 2012 9:55pm
JustinP
My guess is in the screen unit, but I've not really looked.
Post #107021 12th Feb 2012 10:07pm
its the cold.....mine goes dim on start but after its warmed up its back to normal...
i'm not sure but doesnt the dash light dim also dim the nav? ... - .- -.
Post #107053 13th Feb 2012 9:10am
+1 we get lots of phone calls trying to get this rectified... Always the cold!
Craig Thumbs Up
Post #107065 13th Feb 2012 9:38am
JustinP
FYI the light sensor is above the navigation button in the top right corner.
Post #107077 13th Feb 2012 11:04am
