Home > Maintenance & Mods (L322) > BMW Upgrades
Page 1 of 3 123>
mjdronfield
BMW Upgrades
Do we have any sort of a list of the upgrades BMW did to the parts on our cars , but Land Rover never had ?
I'm thinking ;
1) Mk4 DVD based Sat Nav
Is DVD based, so much faster operation and has more areas covered on a single disk. With later updates, you can have a 3D map perspective view and postcode search. You will lose the Off Road Navigation facility though, and the Navigation voice changes slightly.
The units have "DVD" printed on the front of them.
2) Digital hybrid TV Tuner
Allows you to receive Digital Freeview television in your car. You will need this as the analogue signal gets turned off in the UK.
3) Crankcase Breather Filter
The original foam based filter can get blocked and cause turbo failure amongst other things, if not chenged regularly. BMW redesigned the unit to just be like a plastic cone vortex, so can never block.
I think you can just replace the filter part, though you can replace the whole unit if you prefer.
The part number I have is BMW 11127799224
For the filter only, its BMW part number 11127799367 "Oil Seperator"
4) ULF Bluetooth phone module
Allows your car to automatically connect to your mobile phone using bluetooth, you then have a very expensive 4 wheel drive hands free kit !
Dont bother with a 1st or 2nd Gen ULF, get the newest one you can.
84 21 6 915 563 end of life 10/02
84 10 6 931 854 end of life 03/03
84 21 6 934 552 end of life 06/03 1st generation
84 21 6 938 610 end of life 10/03 2nd generation
---Don't bother with the above unless its dirt cheap--
84 21 6 934 961 end of life 03/04 3rd generation
84 21 6 950 089 end of life 06/04 4th generation
84 21 6 945 387 end of life 01/05 5th generation
84 10 6 955 522 end of life 10/05 6th generation
84 10 6 969 268 end of life 04/06 7th generation
84 21 6 958 358 end of life 05/06 8th generation
84 10 6 987 546 end of life 9/06 9th generation
84 10 6 980 130 end of life 11/06 10th generation
84 10 9 133 329 end of life 1/07 11th generation
84 10 9 145 007 end of life 05/07 12th generation
84 10 9 154 358 current production 13th generation
5) Upgraded microphone
The newer unit has noise cancelling built in, so your voice is clearer to those who listen to you speak on the phone.
BMW p/n 84-31-6 938-762
there must be more ?
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #105791 6th Feb 2012 11:34pm
i dont think there is ..maybe you've just started one.. Thumbs Up ... - .- -.
Post #105824 7th Feb 2012 9:39am
As Scarey said Smile
Stick Part numbers on as well and what the upgrade has that is better than the standard unit Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #105831 7th Feb 2012 10:11am
mjdronfield
I have just re-edited my original post with the information I have.
Obviously, more detailed specific information can be found using the search facility.
I understand there is an upgrade to the BM54 radio/amp module, but can't see much about it.......
(UPDATE 7/3/12) I have had my amp upgraded and done a thread here ;
http://www.fullfatrr.com/forum/topic10342.html
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #105960 7th Feb 2012 7:06pm
tsadpt
I know it's not electrical, but one of the best bang for buck BMW sourced mods I've done is the BMW storage/first aid bins under the seats....
Post #106325 9th Feb 2012 2:02pm
More details please Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #106329 9th Feb 2012 2:23pm
tsadpt
What, of the bins?
See this thread:
http://www.rangerovers.net/forum/6-range-r...d-box.html
Very Happy
Post #106339 9th Feb 2012 3:19pm
daveo
auto lights with rain sensor Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #106439 9th Feb 2012 9:47pm
Reformed
Mine has the first aid storage bin under the passenger seat complete with unused and sealed Land Rover first aid kit in it, I thought they would have all had this? Reformed
Post #106441 9th Feb 2012 9:53pm
I think mine has, too.
Auto lights and rain sensor. I like that a lot! Si. <This is my name.
Post #106463 10th Feb 2012 7:52am
I'll have to check that first aid kit but mines half ford bits Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #106465 10th Feb 2012 8:35am
Here's my underseat first aid box.
Nothing in it, though. Luckily, I have a few new travel kits that I constantly nicked out of my Australian HiLux 'ute when I was working over there last year... Whistle
Post #106733 10th Feb 2012 11:06pm
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
Hi
I'm interested in the mic upgrade.
See my post here;
http://www.fullfatrr.com/forum/post106984.html#106984
Did you have the same round ford mic as i have to start with - or did you have the older BMW one and replace it with the new BMW one?
Thanks
Post #106986 12th Feb 2012 8:31pm
mjdronfield
Hi mate,
I have the BMW microphone, as my car is pre-touchscreen.
I don't know much about the Ford system, but as your thread states, a brand new microphone from the Ford dealer has the same issue as the original one, so I'd imagine it has not been upgraded at any time.
Perhaps others with Ford parts can help.
The BMW unit has 3 connections ;
Positive input signal microphone (voice input)
Negative input signal microphone (voice input)
Shield wire connection
If the Ford setup uses these, you could in theory interchange microphones perhaps ?
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #106999 12th Feb 2012 9:20pm
Aurrian
Hi
Thanks for that.
The mic i have has only 2 wires - red and black. Not sure what a shield wire is.
I've just ordered the crankcase breather filter too!! Now see what you've started.
I fitted the egr bypass last week, and got a new hybrid tuner the week before - so keen for another project...
Post #107011 12th Feb 2012 10:15pm
Page 1 of 3 123>
