Home > Maintenance & Mods (L322) > 2010 LED Install Guide
This topic is locked: you cannot edit posts or make replies.  Down to end
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Ok Here’s my install pics from installing my LED rear lights
The kit
Part numbers on lights
I sourced the grommets for the lights to fit into direct from LR part number LR000081 they costed about 22p each
The install isn’t for the faint hearted as u have to remove the old lights and mounting brackets inside as per these pics
Once the old brackets are remove (I twist them off with a pair of pliars) ur then left with the working area to start prepping for drilling the 7mm holes for the new grommets to be inserted
I run a couple of lines of masking tape inside the panel and worked out where the light would sit and pushed firmly on the light creating a imprint in the tape, a couple of things to allow for is the contour of the light to the body and the lines lining up, I used my iphone flat surface to ensure they were lined up with the side of the car if that makes sense, after I got my mark in the tape I centre punched the marks and drilles. I painted all disturbed areas with anti rust and a touch in pen to make good and also riverted and sealed the hold I made pulling one of the brackets out
Grommets in the holes remember 7mm hole
One light in and fitted
I then repeated the above process for the other side, hope this info helps someone
Difference in rear lugs of lights
Original lugs
New hook style lugs
Before and after shots
Hope this helps someone, the wiring was idiot proof and as u see in the kit pics there was full coloured instruction crimper and crimps all supplied, i have no errors fog light issues or disco effects now the correction wiring boxes are installed
Thanks
Neil
Post #104242 29th Jan 2012 7:20pm
This topic is locked: you cannot edit posts or make replies.  Back to top
