Home > General > Bad Wind Noise ? Top of dash ?
Red Desert
Germany
bogie wrote:
I had this - it was the screen scuttle trim - the bit of black plastic that runs the length of the screen
slightly warped with age, and got more and more noisy as you got faster
try putting a strip of tape along the edge where screen and plastic meets and fasten it down tight - if the noise goes away, then youve found your problem
you can try refitting or bodge a re-seal of it with some black silicone etc, but to be honest, it was �40 for a new one, so thats what I fitted and its been fine since
This is it ! Had the same issue.
I fixed the entire length of the rubber seal on the windshield with tape and then suddenly the noise has gone. Thumbs Up
Post #684784 5th Feb 2024 12:01pm
