![]() | Home > Maintenance & Mods (L322) > coolant leak from back of engine (solved) |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
ive tried searching wiki to get a diagram of the coolant pipes at the back of the engine but with no joy..
also theres a link to this part and i think that may be the part im after sorting
This should give you a diagram of the cooling system
thanks nice day but ive sorted it now ...ive managed to cut the hose back enough to loose the hole and now just gonna order a new one from brit part |
i just need to see if i can find the uk part number so i can order one as ive checked britpart and had no joy also the part isnt shown in the files that niceday posted |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Microcat online should help you to identify the part number.
Pret
cheers rob thats the part mate |
Good stuff. I couldn't get mine off the manifold until it was removed from the car. A good test for a leak is drive the car as normal. Lock it up as normal and in the morning open the bonnet and take the lid of the expansion tank. If you get a hiss your doing good as its holding pressure. If you don't it's loosing the pressure somewhere. Be it a leaking hose to the deaded HGF. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
