Home > Technical (L322) > Switch beneath the steering column
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi Folks, Just joined the forum as I read it so much I thought I might as well get involved a bit more.
I was cleaning out the drivers side footwell on the RR and noticed there is a small rocker switch mounted on the underside of the kick panel (so not visible unless you get on bended knee and look upwards). It is basically at the base of the steering column. It has two arrowvs pointing left and right and so , due to curiostiy, I clicked the left side which I think turned my LCD dashboard display on for a few seconds. Could not find it in my car handbooks (as I expected) . Anyone got any ideas what it's for (mines a Vogue SE by the way in case this has any bearing on the matter).
Cheers, Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #5060 18th Apr 2009 11:41pm
If memory serves me it's to disable the cars electrics during delivery and is disabled during the dealers PDI. From then on it's main purpose is to confuse the curious Thumbs Up 2008 MY Supercharged
Post #5061 19th Apr 2009 7:46am
Mudplugger
England 2016 Range Rover Vogue SE SDV8 Waitomo Grey
This had always had me curious too. So post PDI is it correct to say it has NO function?
Could I disconnect and use the switch for something else?
Muddy Range Rover Vogue SE SDV8 - L405 (now sadly sold)
BMW i3 (fantastic little runabout)
Kioti NX6010 Tractor
Yamaha Big Bear ATV
And a whole heap of other kit...
Post #5063 19th Apr 2009 11:22am
Are you mad? For all we know you might end time and stop the Universe!
I might be wrong but do you want to risk it? Rolling with laughter 2008 MY Supercharged
Post #5070 19th Apr 2009 7:39pm
RRVSE
Thanks for that folks. Funny thing to have in such an accessible place. Mind you, it did take me 15 months to spot it in the first place I suppose!! Very Happy Why do I know I'll end up clicking it to the right at some stage, unintentionally of course.
Ta Steve
Post #5073 20th Apr 2009 1:30am
BBS SPY
Cyprus 2003 Range Rover HSE 4.4 V8 Java Black
Before delivery Later L322's are shipped with a special orange relay unit connected to the battery + terminal, onto which the original battery terminal feed is also connected and a small 2 pin plug.
It is designed to disconnect the cars entire electrical system unless sufficient current is drawn, as in starting the car, or the over ride switch (hidden as described) is turned on.
The first step on PDI, which i have myself completed, is to remove this relay unit, and connect the cars + battery terminal directly. the 2 pin connector is then simply shoved down the side by the battery and no longer used for the cars life.
flipping the switch should have no effect.
Post #5082 20th Apr 2009 11:41pm
RRVSE
Thanks for the extra info. Any knowledge of these things much appreciated.
Ta Steve
Post #5083 21st Apr 2009 8:25am
Mine doesn't have this switch under the sterring column. (06MY) Discovery 4 HSE
Post #5086 21st Apr 2009 10:28am
BBS SPY
I believe it was only the later more fully CAN bus vehicles that had it. Not sure if they still have the Pyro Isolater fitted, which can, by control from the Airbag ECU, explosively disconnect the positive battery Lead.
Post #5087 21st Apr 2009 11:35am
The poster's vehicle is the same age as mine though so that doesn't make sense. Discovery 4 HSE
Post #5092 21st Apr 2009 4:18pm
BBS SPY
Diesel L322's did not get converted to CAN BUS until the introduction of the TDV8, with the exception of the entire infotainment system which was fitted from 2005 on to all models and is is all linked together by the MOST fiber optic bus. Therefore a 2006 Petrol is mainly CAN and a 2006 Diesel mainly BMW.
BY CAN BUS i mean fully integrated and connected to the Diagnostic bus rather than where just a few ECU's have a private internal bus between them.
Post #5093 21st Apr 2009 4:54pm
Nice clarification!
Top Marks, GO TO THE FRONT OF THE CLASS! Thumbs Up Discovery 4 HSE
Post #5104 21st Apr 2009 8:50pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Can someone explain what is the use of the funny shaped hole near the lamp (the circled one)? It doesn't seem to have any visible purpose...
Post #14849 14th Mar 2010 3:29pm
JMC
RRVSE - I found this switch some time ago (took me just less than a year! Embarassed ). The consensus is that it shouldn't actually do anything. If you press and hold it in either direction then the whole ignition system stays live. Interesting from a theft perspective I think...... Evil or Very Mad
Dealer has told me that it ought to be rectified and will be next time I'm in there. Read more here:
http://www.fullfatrr.com/forum/topic943.html The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #14871 15th Mar 2010 10:51am
dan_uk_1984
The buzzer/gong goes in there:
Post #14924 16th Mar 2010 12:25pm
