Home > Maintenance & Mods (L322) > Maintaining my DPF this week |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2804 |
The car clears the soot itself by burning it at >600deg C and turning it into CO2 + a bit of ash during a normal DPF regeneration. 2012 TDV8 Vogue (L322) |
30th Apr 2024 10:51am |
jtq4u Member Since: 23 Aug 2023 Location: Portsmouth Posts: 37 |
Indeed that is the design (that it burns it off). However, as with all vehicles that have a DPF, ash accumulates and cannot be burnt off by the car itself. Big lorries were having their DPFs washed out long before they were even put in cars.
30th Apr 2024 1:29pm |
The only way to remove ash from your DPF is to cut it off the exhaust and backflush it in a machine. 2012 TDV8 Vogue (L322) |
30th Apr 2024 1:37pm |
Unless of course the chemical used is breaking down (or dissolving into the liquid) the ash into small enough parts that they pass through the filter during cleaning. There was an interesting video I watched a while back where someone tried various chemicals to see their effect on ash extracted from a dpf vs soot. One needed Alkali and the other acid I think. As a solution can't really be both, it will depend on which the Wynns fluid is. Of course, as you say their instructions direct using it off vehicle, where it would work as a cleaner, back flushing, in either case.
30th Apr 2024 3:28pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1111 |
DPF cleaners lower the temperature of when the soot particles burn off.
30th Apr 2024 4:02pm |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 86 |
2000 Honda S2000 |
30th Apr 2024 6:55pm |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 184 |
I’ve been driving trucks for just over 20 years and not once have I ever had a DPF “washed out” |
30th Apr 2024 8:27pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4253 |
Begs the question….has it worked? Is the differential pressure V reduced? Is it regenerating normally? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
30th Apr 2024 8:48pm |
Trucks mostly do long journeys and are worked hard 2018 SE SDV8 4.4 Byron Blue |
1st May 2024 11:15am |
Maybe it isn't true that Trucks (HGVs, busses, commercials etc) don't get theirs regularly cleaned, though there is a lot of content on the internet suggesting they do - of course there is also a lot of completely false stuff on the internet - just because it is written doesn't make it true! There are quite a few companies out there offering commercial DPF servicing (eg commercial vehicles) like this one: https://excalibretech.com/hgv-dpf-cleaning/ "For instance, commercial vehicles, such as lorries and buses, have a higher mileage, and the DPF filter requires frequent cleaning. On the other hand, personal cars have lower mileage, and the DPF filter may need cleaning less frequently." If it is true it is likely to be because for every cycle of DPF regeneration there is a percentage of the burn that becomes ash. When you are talking 100,000s miles like is quite normal for a commercial vehicle this is likely to happen before the end of life of the vehicle. Whilst it means the DPF regen cycles will be completed as required (even passive ones too perhaps), on a well exercised lorry.. the amount of ash will still end up collecting. |
1st May 2024 11:24am |
Indeed - the proof of the pudding will be in the eating. When I have travelled enough miles I will be able to see if the interval between regens is extended by my cleaning activity. Differencial pressure is harder to be sure of, as I have noted that at idle this is always a lot less than when under load with the turbo spooled up at the same revs. I guess that makes sense of course because there is more pressure coming out of the turbo! For me success will be not having amber's and reds plus an increase in the regen interval.. suggesting an increase in capacity. The service manuals suggest 300 miles between regens.. I have been getting around 70 - 100. (about 3.5 to 5 miles per gram as some people choose to measure it). I will post back after some time has passed to feed back as to whether it was a waste of time or not |
1st May 2024 11:30am |
Lots of info on here about DPF's and regeneration thereof. If you are getting regular warnings either your driving style is too many short trips or you have a airleak on the intake. If the DPF is full of ash and past it's capacity to hold soot without causing excessive back pressure then there is a specific fault code for this and not just a DPF full warning. 2012 TDV8 Vogue (L322) |
1st May 2024 1:31pm |
Yeah I've been reading up on DPF content on this forum and the Facebook ones for about a year, as well as on every other source I can find. I even had a private email exchange with a guy who had talked to the RR design team.
1st May 2024 1:53pm |
By the way I don't intend to pretend if the clean helped, and will try and stay away from the placebo affect. I promise I will own up if it is no better afterwards
1st May 2024 2:00pm |
