Home > In Car Electronics (L322) > L322 2008 vs 2012 entertainment screen is sharper in 2008 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Mine looked dull until I removed the outer screen layer that was worn with Autosol chrome cleaner.
29th Apr 2024 9:15pm |
fatu Member Since: 02 Feb 2024 Location: Prague Posts: 21 |
Interesting thanks I might try that. I don’t have any wear and tear it is just not as sharp as it should be, I feel. I thought maybe some resolution change on some secret menu settings can help but I guess nothing like that… Range Rover 2012 4.4 TDV8 - current
29th Apr 2024 9:46pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 213 |
That’s interesting- I’ve recently got a newer one after my 07 and I thought the opposite- I thought straight away the newer screen was better- the rear screens on the newer one is definitely a lot better 2009 (2010 MY) 5.0 Supercharged Autobiography
30th Apr 2024 8:19am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1260 |
Do you have the dual view system ? If so, that is less sharp / crisp than the non-dual view system I think. V8 or else ... |
1st May 2024 8:37am |
Yeah, I’ve got the dual view system.
1st May 2024 9:11am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34955 |
from memory isnt the aspect ratio different between the two years...that could make it look less sharp. ... - .- -.
1st May 2024 9:32am |
Makes sense, i have dual view...it is shame I see single view images in google and they are really sharp. Is there a way to shut down the dual view to make it sharper? just trying to think of a way. Thanks for the info. Range Rover 2012 4.4 TDV8 - current Range Rover 2008 3.6 TDV8 - previous Range Rover 2004 3.0 TDV6 - previous |
17th May 2024 11:19am |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 152 |
replace with single view unit. |
18th May 2024 2:14am |
