Home > Technical (L322) > 4.4 TDV8 GearBox Leak
rhjackson
United Kingdom 2011 Range Rover Vogue 4.4 V8 Bonatti Grey
Hi, my MY 2011 4.4 TDV8 was reluctant to change gear today and shuddered slightly when going down a hill. On looking underneath there is a constant drip of what appears to be transmission fluid.
Any suggestions of what it could be before I choose which garage to book into (either will go to gearbox specialist or local garage).
Thx in advance
Post #691457 28th Apr 2024 11:41am
JayGee
Could be leaking from the gearbox pan seal. the electrical plug or the cooler and pipes. Maybe worth trying to see if you can identify exactly where as if it's draining away you won't be able to drive it. 2012 TDV8 Vogue (L322)
Post #691459 28th Apr 2024 12:40pm
rhjackson
Thankyou. I had a look and could not see any wet areas. Maybe it only leaks when the gearbox is hot. It did smell like a clutch smell initially which made me look underneath (i know they don't have clutches but similar smell)
Post #691497 28th Apr 2024 8:35pm
