Hi guys,
I have (maybe two) strange things happening with my TD6. It has 158k miles and is still on the first gearbox. The towbar was fitted by me two years ago and I never towed something heavy since that.
Since last year I have a drone starting from ca. 35mph which is in my opinion coming from the front. It is also present in neutral so I would rule out the gearbox. I changed the wheel bearings, differential oil (which looked good) and tried different tires. Nothing helped. This weekend I was on the lift while running and tried to heat something under the car. Everything sounds fine in my opinion. I read about the center prop shaft bearing so I dismantled the heat shield and the rubber from the bearing looked still good.
Then I noticed something which is maybe connected but I'm not quite sure if that's the case. In drive and while on the brake, when I turn the steering wheel left on nearly full lock a heavy vibration starts. That is not the case while steering to the right. I noticed the engine moves about 2cm to the left when steering left. Does that point to broken engine mounts? Apart from that the seem fine.
I would be very grateful for hints what to check, I'm out of ideas and it's really annoying me because the car runs great apart from that.
Cheers
Gary
