Home > Wheels & Tyres > New Defender Alloys With 255/60 20s On L322 2012 Westminster |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 532 |
Picked up new set of Defender Alloys with 255/60 x 20 Scorpion Zero All Seasons from Sonearly.
29th Mar 2024 5:49pm |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 204 |
What’s it like in access mode? |
29th Mar 2024 6:24pm |
Vertical clearance is fine, drove it around in circles forwards & backward no rubbing at all now. Been bouncing it over speedbumps this afternoon nothing touches,
29th Mar 2024 6:30pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35217 |
i think it looks good Andy, fills them arches well.. ... - .- -.
29th Mar 2024 9:13pm |
Dragonoak4x4 Member Since: 31 Dec 2023 Location: Misson Posts: 8 |
18th Apr 2024 6:45am |
For the front arch I got a bit of 2 x 2 and cut to length, pushed it between the arch liner and the front hub with the wheel off, so the arch liner was forced to beyond where I wanted it to be, then with a heat gun went all around the "gills" area getting it hot, but not melting when I was happy removed the heat and let it cool with the wood in place, I think 10 minutes tops.
18th Apr 2024 8:58am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4295 |
So, does that mean an L322 wheel will fit a new Defender then?
18th Apr 2024 7:20pm |
Not so simple as the ET differs by 15mm. Defender wheel on L322 means the track extends by 15mm on each side so not much of a problem.
18th Apr 2024 7:31pm |
Cheers. Excuse my ignorance but what does ET mean?
18th Apr 2024 7:33pm |
Not sure, something in French I think. Its the distance between the centre of the wheel rim and the mating face of the wheel to hub vertically in mm
18th Apr 2024 7:42pm |
Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Apr 2024 8:52pm |
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 51 |
Disco 5 alloys on my 2004, 9.5" wide, 21" wheels, do fill the arches, with no rubbing....
19th Apr 2024 2:01am |
Looks nice, sparkle silver contrasts the dark colours nicely. Fuji White / Jet 2012 4.4 TDV8 Westminster |
19th Apr 2024 6:28am |
LukeKnott Member Since: 22 Apr 2024 Location: Warwick Posts: 4 |
I know it's only been a few days, but how has it been living with these so far? I have the opportunity to bag an unused set of 5 for less than it costs a set of tyres normally! |
22nd Apr 2024 1:54pm |
