Home > Technical (L405) > Heating/cold air issue |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 123 |
You need to pull off the lower centre side trims and see if the air flow door actuators are moving. It is a common problem for the plastic tooth drive to slip or lose teeth and get stuck. They also have moving metal strip contacts that wear and wear out. You can also check door position on enabled OBD readers, you should see the various door positions move in real time as you change the dial settings unless they are, of course, no longer working.
7th Mar 2024 10:27am |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1010 |
Thanks that’s really helpful and reassuring that I’m not going mad!
7th Mar 2024 8:21pm |
Resurrecting this thread…..
30th Mar 2024 6:11pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3127 |
It may probably be the known problem of a sticky refrigerant control valve (RCV) in the a/c compressor.
30th Mar 2024 8:52pm |
