Home > Technical (L405) > heated seats
caymanblack
heated seats
My heated seats are so hot i,m sure they would cook me if i left them on is this right or is there a problem i can only use them on the first setting , boiling. Even my steering wheel gets to hot on my old sport it used to ease off after a certain temp but not this car. overfinch modified
Post #686363 24th Feb 2024 3:41pm
JamboM3
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
I don't find mine particularly hot (MY17). My L322 was much hotter - perhaps you have an issue?
I do find the steering wheel quite hot though, I like that though
Post #686435 25th Feb 2024 3:46pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Compared to my L322, the seats in my car don’t get as warm, nor do they cool as much. If your’s are getting too hot, I’d say there was an issue with them, but being an electrical ingoramus, I couldn’t say what it might be.
Post #686445 25th Feb 2024 5:33pm
caymanblack
Thanks all , i,m sure they cant be right. overfinch modified
Post #686518 26th Feb 2024 7:12pm
supershuttle
I think you're right, I have mine on pretty much all the time (lowest setting) and find them comfortable. Geoff
Post #686539 26th Feb 2024 9:53pm
caymanblack
The thing is does anyone know what can cause this? I cannot have them on anything but the lowest setting and even then I have to turn them off , will have to check passenger seat also. overfinch modified
Post #686613 27th Feb 2024 2:47pm
i guess theres an ECU or some kind of regulator/temp sensor that might be faulty..
have a look in the WM , i'm sure there will a diagram showing whats what. ... - .- -.
Post #686615 27th Feb 2024 4:00pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I seem to have the opposite issue. Unless my seats are cranked up to max I can’t feel any heat. Even on max it is just about warm and not hot. My previous cars (BMWs) were all capable of giving third degree burns. So interested to know if there is a temp regulator that may be causing my low temp and also the problem the OP is raising of too hot.
Post #686624 27th Feb 2024 7:41pm
Mine are very weak too! Sad
Post #686652 28th Feb 2024 12:16am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Same here, heating is very weak. Cooling is OK though and was very nice last year in the South of France. The heated seats of my wifes Freelander 2 are much better at heating.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #686680 28th Feb 2024 2:03pm
garyRR
I have a 2015 L405 Autobiography. You have the heated and cooled seats (heated and cooled use a different system to heated only), the seats will cook you if on setting 3. I'd consider this perfectly normal and the sign of a healthy peltier cell.
I can use heat setting 1, which I would consider warm enough. 2 and above aren't tolerable for me, but the other half loves sitting there and becoming a casserole.
It was the same on my L322, which I put new Peltier cells in. 2015 Range Rover Autobiography 4.4 SDV8
Post #686712 28th Feb 2024 7:45pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Mine are roasting hot same as steering wheel, I have no complaints on mine
Post #686717 28th Feb 2024 8:07pm
caymanblack
I thought something was wrong as these seats are much hotter than on all my previous Range Rovers and the steering, but obviously, there is not a problem as others also have seats hotter than their ovens.
Shocked overfinch modified
Post #686719 28th Feb 2024 8:17pm
DrF
Toasty testicles hot Thumbs Up
Post #686720 28th Feb 2024 8:18pm
caymanblack
Rolling with laughter Exactly I want to keep my in shape not burnt out! overfinch modified
Post #686753 29th Feb 2024 9:59am
