Home > Wheels & Tyres > L405 Rims on a 2012 L322
robkuijpers
Netherlands
Dear forum
Another thread with similar title focuses on the looks of new rims on an L322.
My question is pure technical: will L405 rims fit on an (2012) L322:
- Are the nuts/bolts/geometry the same
- is the rim's offset the same
- any problems with the brake caliper's size?
- Will the TPMS of a L405 rims work on an L322
There are plenty of used L405 rims (with winter tires) on the market and there is a bigger choice then L322 rims.
Do you guys have any experience here? Any guidance is high appreciated.
Regards
Rob 2012 RR Vogue 4.4 TDV8 Sumatra Black
2004 Defender 110 Td5 Epsom Green, 'Alive' Chip tuned and a Warn 8274 Winch
1978 Citroen Mehari Orange Kirghise
2001 Defender 90 Td5 Softop (gone)
1992 RR Classic 300TDi 'Soft dash' Green (gone)
1989 RR Classic V8 Caspian Blue (gone)
Post #683028 17th Jan 2024 7:44pm
Stuart-
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
I fitted L405 rims on my L322 without issue, so yes, but I had to swap the TPM sensors over IIRC. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #683035 17th Jan 2024 9:12pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
I had both these 20" wheels for my L322. The 20s are interchangeable between L322, L405, Disco 4 and 5 and Range Rover Sport L494. Offsets are the same.
Post #683045 17th Jan 2024 11:07pm
