Home > Maintenance & Mods (L322) > Car completely dead |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3162 |
How old is the battery? 2012 TDV8 Vogue (L322) |
11th Sep 2023 4:36pm |
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 55 |
It was changed around 6 months ago, have been having the "battery low please start engine" message every now and again |
11th Sep 2023 4:42pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 472 |
Iโd be tempted to go into the secret 753 menu and look to see what the voltage is with the engine running, just to rule out alternator problems. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family ๐
11th Sep 2023 5:16pm |
Just checked the menu and battery voltage is showing 14.3 volts |
11th Sep 2023 6:11pm |
Thatโs a relief 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family ๐
11th Sep 2023 6:47pm |
I assume this is when it's running and charging. What's the reading when the engine is not running ? 2012 TDV8 Vogue (L322) |
12th Sep 2023 9:25am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Is your no start symptom, a tiny click when start button pushed, and the display going blank? -over and over again? And radio and headlights all ok? |
12th Sep 2023 10:55am |
It did have a click and the display going on and off but I'm not sure about the radio and headlights |
12th Sep 2023 12:40pm |
ok, so this symptom has been very popular on the 4.4 l322 diesel. the starter trigger wire has a high resistance joint somewhere in the route from the fuse box to the starter motor. many have simply replaced the starter motor, which sort of gives a fix, but it just makes it easier to spin it up, so the trigger wire fault is not as apparent.... as with a tired starter.
12th Sep 2023 5:11pm |
Thanks for this mate will have a read, I've tried putting the battery that I replaced on charge with a trickle charger and it's showing 40% which is making me think something has drained it |
12th Sep 2023 5:14pm |
Currently showing 11.9 volts with just the ignition on |
12th Sep 2023 5:18pm |
11.9v is OK with ignition off. 2012 TDV8 Vogue (L322) |
12th Sep 2023 5:22pm |
my alternator died once, right outside my house ....fortunately, it went out in style, with copious smoke and dash bongs galore. but it took the battery out too. by the time i got the terminal off, it had about 9 volts... it was lucky it didnt burst open. the issue with the starter, was with a perfect seeming battery, at around 12.65 volts. |
12th Sep 2023 7:43pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
11.9v is less than 40% charged, a Lead Acid Battery should not be discharged below 50% (12.05v) BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
12th Sep 2023 8:11pm |
