Home > Technical (L405) > Tinny vibration at 1900 rpm - 2020 L405
MAE
United Kingdom 2019 Range Rover Vogue SE SDV6 Indus Silver
I note there are references to this issue in past posts but now experiencing this issue myself I wondered if anybody ever identified what was vibrating at this point in the rev range. It sounds like it's coming from under the car at the rear of the cabin and is quite a 'tinny' sound and only at around 1900rpm. -----------------------------------------------
Indus Silver L405 SDV6 Range Rover 2020
Defender 90 Puma 2014
Discovery 5 HSE 2017
Discovery 4 HSE 2016
Post #666253 9th Jun 2023 1:47pm
normally and hopefully its just an exhaust heatshield rattling.. ... - .- -.
Post #666258 9th Jun 2023 2:18pm
MarianaWestminster
As Stan says it's usually a metal heatshield mounting bracket underneath the gearbox that gives a tinny rattle.
My 2016 car has a 'resonance' at 1030-1500 ish rpm with a sound that is like someone blowing across a bottle top.
I checked underneath and my car doesn't have the metal bracket on the gearbox or the heatshield attached to it.
Instead it has a huge metal bash plate covering it all.
I'd imagine a 2020 model is the same and just has the big bash plate.
Post #666280 9th Jun 2023 4:59pm
Seatown
Scotland 2013 Range Rover Vogue SE SDV8 Firenze Red
A 2016 model may well be different but my 2013 car also has a bash plate under the gearbox. The heatshield and its mounting bracket is above that. I had to remove the plate when I investigated/fixed the fractured gearbox heatshield so I wouldn't rule out your car having one.
Post #666303 10th Jun 2023 9:04am
knwatkins
I had a virbration with the gearbox heatshield (above the bash plate). Nothing was visibly bent so I used some self-adhesive velcro (the fluffy bit) to line the underside of the bracket and isolate the metal to metal interface between the bracket and heatsheild. It is now silent. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #666347 11th Jun 2023 8:57am
Seatown
Kev, I did exactly the same with mine but unfortunately it didn't cure the noise/vibration. I removed the heatshield again, cleaned it up and discovered a crack round one of the bolt holes. So a new heat shield required.
Post #666353 11th Jun 2023 9:33am
MAE
Update
It was a faulty silencer, the insides were vibrating. Replaced under warranty. -----------------------------------------------
Post #675340 11th Oct 2023 6:54pm
fisha
Bit of a thread resurrection, but added to help others who find the thread. my rattle has come from the black cross bracket that cradles the gearbox and to which the smaller heatshield attaches to … I’m seeing if a pal can reweld it. It’s one heck of a split though … not something I would expect to happen.
Cross bracket:
Split :
 V8 or else ...
Post #692275 9th May 2024 8:16pm
pierre_l
Switzerland 2014 Range Rover Autobiography SDV8 Santorini Black
Same here
Anyone had a dealer do it? What should I ask for?
I have them but they say they don’t hear it !
Post #693225 24th May 2024 5:13am
jensputzier
Germany 2019 Range Rover Autobiography 5.0 SC V8 Loire Blue
I have the same snaring or tinny sound at 1500-2000 rpm, sometimes louder, sometimes less. Mostly when accelerating or decelerating.
It started at appr. 20k kms.
I asked my son to pass by the dealer who said I drove over something that scratched a wishbone and an exhaust shield and they kind of bent it back again.
I looked under the car today as good as I can but did not see any scratch whatsoever.
But I noticed that the heat shields between the rear mufflers and the body were a bit loose.
Maybe this is the reason, I need to look deeper into this.
Post #698331 18th Aug 2024 6:06pm
fisha
You couldn’t see the crack on mine until you had the heat shield off and were taking the frame off. For me, it was a case of just pulling and pushing at parts as I disassembled the underside shields till I found the problem.
My initial thoughts were that it was just a loose shield, so would stick some foam or felt type material between the bouncing surfaces as suggested above. V8 or else ...
Post #698363 19th Aug 2024 7:35am
Gremlin500
Please bear in mind, do not use combustible material as padding anywhere near the exhausts, particularly with the DPF-equipped vehicles.
During active regen, exhaust temperatures can easily reach 650 deg.C, that’s as hot as a blowtorch! :shock:
Post #698378 19th Aug 2024 10:46am
