Home > Maintenance & Mods (L322) > egr blanking kit for td6
Page 1 of 15 123 ... 131415>
i wonder if this really does give you better performance and mpg..
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWAX:IT
Post #72501 15th Jul 2011 10:42am
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Give it a go Stan. Its only 40 quid Thumbs Up FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #72509 15th Jul 2011 10:55am
i'm waiting for someone who 'knows' about egr and if its worth blanking or not...my engine is running very well at the moment and i dont want to upset it.. Laughing
Post #72532 15th Jul 2011 1:15pm
pretlove
i think my brother did something similar on his disco 3 and he said it was much better "RANGEISM WILL NOT BE TOLERATED"
Post #72537 15th Jul 2011 2:10pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
There's a thread on rrsport about this http://www.rrsport.co.uk/forum/topic18862.html
Post #72539 15th Jul 2011 2:54pm
My dad has done it to his TD6 Disco2 and is very pleased with the results. A bit smoother, and 1-2mpg extra. Not loads but worth it. He thought his throttle response was a bit better too.
Post #72541 15th Jul 2011 2:58pm
GregP
Are they easy to fit?
Any long term issues that they can cause in comparison to original part? FFRR TD6 HSE
Post #72542 15th Jul 2011 3:04pm
GregP
cheaper here peeps
http://www.4muddyfeet.com/shop/product_inf..._id=133244
I'm gunna get my dad to get some prices as well. Will let you know how he gets on as he should be able to get em trade. FFRR TD6 HSE
Post #72544 15th Jul 2011 3:26pm
all the advertisers claim improved mpg and performance so it must be true.. Laughing
Post #72547 15th Jul 2011 3:39pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
For best results I would recomend that anyone doing this removes the inlet manifold and gives it a real good clean out. I was amazed at the amount of crud in my last FFRR after only 78,000 miles.
Adding the EGR without cleaning out is a little like closing the stable door after the horse has bolted. The crud will restrict free flow of the intake and at the end of the day what you want is an engine that can breath out of its mouth instead of its exhaust Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #72549 15th Jul 2011 4:04pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
yes it is a well know fact that these things work, everyone was doing it on the Disco Owners Club, but as stated if you are going to do it i would do a proper job and make sure all the crud that it has fired back into the inlet manifold is cleaned out first. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #72578 15th Jul 2011 6:15pm
GregP
I'll be fitting one next time I'm down at my dads. Will make sure they clean out the inlet manifold as well and will report back on any changes in performance & economy. FFRR TD6 HSE
Post #72585 15th Jul 2011 6:35pm
Be worth cleaning out the inter-cooler while you're at it as well.
Post #72592 15th Jul 2011 6:56pm
GregP
Thanks for advice. I'll add it to the list. Let's hope it all makes a difference. FFRR TD6 HSE
Post #72593 15th Jul 2011 6:59pm
993porky
England 2004 Range Rover HSE Td6 Java Black
Hi everyone, I would say egr are good am going to blank my rangie soon, I have done the egr blanking on my defender td5 I know it's a different vehicle but I had better throttle response and before I done it on defender I was getting 240 miles on full tank whereas now since I done egr I get 290 miles on full tank, best £40 I've spent on my defender which is my daily work horse. Incidentally when my rangie was on diagnostic the other week it showed a egr fault on the computer the same as what happened to defender which prompted me to do egr in first place.
Also my brother had his disco 3 done an he says much better Thumbs Up Range rover hse
Java black
Post #72610 15th Jul 2011 11:20pm
