Home > In Car Electronics (L405) > Land Rover Remote App
Page 3 of 3 <123
Kot
Just keep trying JLR support then Rolling with laughter maybe its not your phone Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #690277 8th Apr 2024 9:47pm
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Crikey, you're easily persuaded Rolling with laughter
Post #690293 9th Apr 2024 9:13am
Jorrocks
United Kingdom 2018 Range Rover Autobiography SDV8 Montalcino Red
My remote app has decided the car is unlocked (It isn’t, I checked!) and won’t update / refresh when pulled down. Any ideas why? My battery is probably getting a bit long in the tooth, only showing 12.47 Volts and 74% state of charge, might that be causing the issue?
 2018 L405 4.4 SDV8 Autobiography
2010 L322 3.6 TDV8 Vogue SE, 171000 miles and counting….
Post #691821 3rd May 2024 12:48pm
Kot
The 2 sunshine symbols indicate its trying to update phone app with your car status and failing to do so.
Try deleting and re-installing the app, is the subscription valid? go to web site and check.
if still the same Contact Incontrol people http://www.landrover.com/incontrol lol maybe customer service can direct you to the Incontrol people.
If you have an OBD2 do a DTC scan, I once had issue where remote thought the car was at the last service station I had visited and after DTC check there was a TCU fault which when cleared brought the location status back to normal, maybe it will help? 2018 SE SDV8 4.4 Byron Blue
Post #691830 3rd May 2024 2:18pm
Page 3 of 3 <123
